John G
| posted on 7/10/25 at 04:03 PM |
Adhesive for metal to metal
Slightly off topic. I am fitting a new register plate above my wood burner. There are angle brackets at the rear and sides but the front has a steel
lintell.
What would be the best adhesive for metal to metal . The plate will become warm when the stove is in use. I don't really want to drill and tap
the lintell.
Regards Jon
scudderfish
| posted on 7/10/25 at 04:35 PM |
JB Weld?
jacko
| posted on 7/10/25 at 07:17 PM |
It’s up to you
When I worked on buses the panels where glued on with sikaflex you had to key the panels first when fitting
The thing is you had to use oxy acetylene to heat the panels to get them off ie very hot
555
jacko
| posted on 7/10/25 at 07:23 PM |
After looking on google JB weld seems to be what you want
G
555
pewe
| posted on 15/10/25 at 10:56 AM |
IIRC JB Weld do a high temp adhesive.
