| posted on 15/7/26 at 05:00 PM |
What bulbs please
  lights-1
What bulbs do I need for this light fitting in my shed?
Partofthechaos
| posted on 16/7/26 at 04:55 AM |
T8 is the pin arrangement and the diameter, 2ft is the length. Can't get the tubes any more, but B&Q should have an LED retrofit that would
work.
SteveWalker
| posted on 16/7/26 at 09:17 AM |
I am assuming that the HF means High Frequency and I see that there are HF LED tubes available. It is possible that the high frequency control is not
compatible with non-HF tubes, so you'll have to buy HF tubes or bypass the HF controller.
| posted on 16/7/26 at 10:06 AM |
Thank you.
coyoteboy
| posted on 16/7/26 at 01:37 PM |
work.
You absolutely can get normal mercury discharge tubes still, legally. It's just incandescents you can't get as readily, though the stock is
reducing.
https://home.lightsave.co.uk/2ft-16w-high-frequency-t8-tube-box-of-25.html?srsltid=AfmBOopqK_kfoKEuyDfBqUHIIv21Sg7kVXr8Ga8vZV2r-I1FyYYU4DAFUu8
But the LED units are perfectly swappable with HF tubes.
My garage has 4 twin T8x5ft fixtures because I hate working in the dark!
[Edited on 16/7/2026 by coyoteboy]
https://www.fixmystreet.com/
| posted on 16/7/26 at 03:34 PM |
work.
reducing.
Thanks coyoteboy - looking good!
