Author: Subject: Drill bit recommendation
John G
posted on 28/9/26 at 06:10 PM Reply With Quote
I did a post a few years ago but can't find it. After a good quality set of drills for steel. 3mm to 12mm.
Regards Jon
cliftyhanger
posted on 29/9/26 at 07:37 AM Reply With Quote
Dormer or Presto are both top notch makes
coyoteboy
posted on 29/9/26 at 08:28 AM Reply With Quote
I usually go for a specialist these days, go to someone like cutwel.
But it depends what you're drilling. The difference between a decent set of HSS and some TCT drill for a mild steel job is minimal, but if you're drilling stainless or something hard, you'll be astounded at the difference.
https://www.fixmystreet.com/
