<<  1    2  >>
New Topic New Reply
Author: Subject: Aluminium chassis?
chunkielad
posted on 11/3/05 at 05:32 PM Reply With Quote
Aluminium chassis?
Alumium frame
Goto builds then alum....
kb58
posted on 11/3/05 at 05:48 PM Reply With Quote
With my admitted limited knowledge, it's a very bad idea. Aluminum work hardens, every bump makes the chassis more brittle - cracks are guaranteed. Anyone who uses aluminum structurally doesn't weld it, instead bonding or rivetting. Lotus for example. Airliners...
Just because someone's done it doesn't make it a good idea. Let's see a status report on this aluminum car after it's been driven 15,000 miles...
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Jermyn
posted on 11/3/05 at 05:49 PM Reply With Quote
I am very curious to know what sort of torsional stiffness figures they are expecting from that chassis. Appears some of the tubes have been substituted for larger widths and some have been added.
I suppose they think that will compensate.
If life is a race do you want to be the first one to finish?
chunkielad
Hey man I am with you!!
Notice the
kb58
posted on 11/3/05 at 06:14 PM Reply With Quote
Which makes the chassis heavier. I wonder, by the time enough tubes are added to make it last, will it be any lighter then steel...
flak monkey
posted on 11/3/05 at 07:55 PM Reply With Quote
Ali is 1/3rd the stiffness of steel...ergo you need 3 times the amount of material to get the stifness back. So an ali chassis will weigh the same as a steel one (for spaceframes anyway).
As already stated, its not advised to create welded chassis' in ali, unless you have the facilities to heat treat a whole chassis when its finished!
Sera
http://www.motosera.com
dblissett
posted on 11/3/05 at 08:36 PM Reply With Quote
ali
in the early eighties i used to race a tz350 bike with a spondon ali frame
very light but it used to crack around the headstock area from this limited esperance i wouldent use ali for a chassis
good luck dave
cymtriks
posted on 11/3/05 at 09:06 PM Reply With Quote
Oh dear
Another aluminium spaceframe.
Aluminium is 1/3 the weight of steel but also 1/3 of the stiffness so copying a steel frame design in aluminium gives a big stiffness loss and a big weight reduction. To get back the stiffness you have to triple the tube wall thickness which triples the weight. This brings you back to the structural properties, weight and stiffness, of a steel frame but at greater cost, lower fatigue life, and more difficult welding.
Avoid.
chunkielad
posted on 11/3/05 at 09:14 PM Reply With Quote
Oh I wasn't going anywhere near it!! Just figured I'd spark a discussion...
scoobyis2cool
posted on 11/3/05 at 09:50 PM Reply With Quote
I won't bother commenting on the use of ally, think we're all decided it's a bad idea, but the name made me laugh - ESTfield - how original!
Pete
Spottty
posted on 11/3/05 at 10:29 PM Reply With Quote
I hope they have video of the first time they floor it, That chassis will twist like a pretzel!!
Best thing to do for a build....
Ditch the wife!
tks
posted on 12/3/05 at 01:16 PM Reply With Quote
Ali Chasis
Well the current analysis isn't right quite yet.
You can make a chasis from ali more stiffer then one from steel. But then you need to use larger diameter tubes because the diameter of a tube gives more strenght to the construction.
But i think that if the steel tube = 25mm round. you will need ali round 40 or something like that.
you still would be less weight.
Thats pure the construcition vision i have.
But offcourse welding a complete chasis isn't a good idea....
Lotus uses a glue for their chasis etc. the main reason is because of if you weld ally it is weaker after it on the place you welded it. Glueing doesn't affect it.
I think the best conclusion we need to do is that a ali construction is very expensive
(material, glue) because if a dry chasis will weight 130Kg i think you need 100Kgs of ali...
Another good idea would be welding it in INOX (stainless steel)....
TKS
cymtriks
posted on 12/3/05 at 04:46 PM Reply With Quote
hello tks
What "current analysis" are you talking about? The book chassis was designed without any analysis. Analysis using FE has been done by me and by Wesley. My analysis and his are both posted in the files section of the locost7.info site. The steel chassis can be greatly improved fairly simply.
Using larger diameter tubes will improve the stiffness of the tubes for the same weight but the effect on overall chassis stiffness will be small. In a spaceframe the tensile properties of the tubes are much more important and as alluminium has 1/3 of the stensile properties of steel you cannot get a weight saving for the same stiffness.
For a ladder frame, in which the stiffness of the tubes is directly related to the overall stiffness then you are correct. A larger tube in aluminium will give a better stiffness for a given weight than steel tubes.
Construction in aluminium isn't that expensive. You need to clean and etch every joint before you apply the glue to get a good bond.
The lotus Elise chassis is not a spaceframe. It is actually close to being a ladder frame as its structure is dominated by those two big tubes that form the sills. I have described the Elise as being a hybrid of ladder frame and monocoque in my analysis and I still think this a good description of how it works.
Aluminium spaceframes are gimicks. Aluminium ladder frames or monocoques can work very well if they are designed properly.
kb58
posted on 12/3/05 at 05:03 PM Reply With Quote
I think part of the issue is that a true space frame puts *no* bending loads in any tube, only tension or compression. For that reason you can use tubing only large enough to resist buckling under compression. OTOH, if you have tubes that will only see tension loads, you could use very small bar stock... or even cable.
Anyway, seems it's best for us to stick to old-school construction practice and stay with steel.
Soul-tez
posted on 12/3/05 at 05:17 PM Reply With Quote
I ride an aluminum mountain bike that is basically a super stiff, super light space frame. The stress that the frame goes through must be really high considering the way I ride. Translating bicycle frame design to a car would be extremely complicated and expensive. The tubes on my Klein bicycle are very large diam. but somehow they thin the walls down to nearly beer can thickness in the middle of the tube and leave it thick at the ends where it is welded. I would guess that if this was practical in a car one of the exotic car companies would have tried it allready. If that frame wasn't heat treated after it was welded I would run from it.
tweek
posted on 13/3/05 at 03:05 PM Reply With Quote
There must be something in the ally chassis idea or you wouldn't get the likes of audi, jaguar an lotus making production cars out of it - cars that have to go hundreds of thousands of miles without they're chassis falling apart!
I do agree with cymtriks tho, from all the evidence i've heard ally spaceframes seem well dodgy.
maybe someone will get round to making a locost ally monocoque? (other than Robin Hood and the famed cheesegrater!)
cheers
"oh dear..." said god,
"I hadn't thought of that"
and promptly vanishes in a puff of logic
chunkielad
posted on 13/3/05 at 04:49 PM Reply With Quote
The problem isn't ali as a chassis but rather WELDED ali SPACEFAME. Welding ali isn't clever for strength (becomes brittle) and I'd much rather trust steel when my ass is 4" from the ground at 70mph
[Edited on 13/3/05 by chunkielad]
Ian Pearson
posted on 13/3/05 at 10:49 PM Reply With Quote
Isn't Ron holding up an MK built ali chassis on page 53 of "BOOK" no 2?
chunkielad
posted on 13/3/05 at 11:59 PM Reply With Quote
Pretty sure that's steel mate.
Volvorsport
posted on 14/3/05 at 12:20 AM Reply With Quote
ally monocoque survive in oz - theres been a few threads about them .
A pared down race chassis could not be compared with a production car .
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 14/3/05 at 07:41 AM Reply With Quote
No its athe alloy chassis MK made up for Ron.
Those of us with long memories have been through this all before.
(1) an alloy chassis to the book design is as usefull as a chocolate tea pot.
(2) Alloy spaceframes can be built BUT they need to be made of thick wall large diameter tubes and even then don't expect it to last more than a few months use due to fatigue problems.
(3) The best way to do it is a a monocoque --- well designd alluminium monocoques are useually HEAVIER but much stiffer than a well designed spaceframe.
(4) The narrow 7 shape isn't best suited to a moncoque.
[Edited on 14/3/05 by britishtrident]
chunkielad
posted on 14/3/05 at 10:51 AM Reply With Quote
Why did MK and Ron do it then?
posted on 14/3/05 at 11:10 AM Reply With Quote
Don't know but I suspect RC thought it would work.
I spent a month of my proffessional life sorting out somebody elses design for a manhole lifting made out of similar but larger (2"x2" ) aluminium extrusion. The corner welds had been failling on almost every machine after a couple of months use . I raipdly came to the conclusion -- it just wouldn't work and needed a complete rethink. I redesigned it based on 2.25" tube and 2.5" H section extrusions. Although the weight went up from 18kg to 25kg after that we had only one failure and that was due a deffective extrusion.
It taught me very valuable leasons
(1) a structure that works when made in steel usually can't be translated straight in to a light alloy.
(2) the importance of good weld design.
(3) aluminium structures fatigue
Ian Pearson
posted on 14/3/05 at 11:46 AM Reply With Quote
Have you tried lifting your steel chassis?
Spoke to Martin at a show when I first started out with my build. He mentioned the alloy chassis. It helped explain why I wasn't able to match Ron's weightlifting ability.
ned
posted on 14/3/05 at 11:58 AM Reply With Quote
I believe the ally chassis was made as a show piece only.
Ned.
beware, I've got yellow skin
<<  1    2  >>
New Topic New Reply
