ady8077
posted on 9/5/05 at 07:03 PM |
type 9 gearbox trouble?
Hi all
I'm finding it hard to find second gear when downshifting, first to second is very slick. could this be the box on its way out or could
something need adjusting?
Adrian
Bart69
posted on 9/5/05 at 07:09 PM |
As long as the other gearchanges are ok it sounds like the box. Have you tried double clutching it
graham
MkIndy7
posted on 9/5/05 at 07:19 PM |
Could it be the positioning of your remote if your using one?
I know ours needed some fine adjustment.
Or possibly trying to change down into 2nd when your still going slightly too fast?
I know some gearboxes don't like that
ady8077
posted on 9/5/05 at 07:22 PM |
Hi
Double cluthing helps but it can still be awkward
Dont have a remote, and tonight i was going that slow trying to find second i stopped
Adrian
MkIndy7
posted on 9/5/05 at 07:32 PM |
So does yours still have the reverse gate on?
Ours has a replicated gate on and you have to press firmly against the gate almost as if your trying to get it in reverse
before pushing backwards altho I think thats when I get carried away and can't find 2nd on the way up!
ady8077
posted on 9/5/05 at 08:06 PM |
Hi
Not sure about the reverse gate, but now you mention it reverse is very easy and i have found reverse instead of first a few times
Adrian
bob
posted on 9/5/05 at 08:14 PM |
I have this problem regarding downshift to 2nd gear,i have a remote which i do think isnt helping.
Also i've selected reverse instead of 1st,i'm sure the box is fine and think its a damaged fork on the selector or the little plastic
saddle the gearstick fork sits over is knackered.
posted on 9/5/05 at 08:40 PM |
if you take the top off the box, you can see the mechanism changing gears - but be careful fiddling, things can fall out with the lid off! took me
half an hour to get it all back together!
ady8077
posted on 9/5/05 at 08:55 PM |
Hi Bob
Is your 5th gear a bit awkward?
JoelP do you mean the main cover or where the gearstick bolts on?
Adrian
bob
posted on 9/5/05 at 09:17 PM |
Adrian
5th gear hasnt been a problem so far,i think my problem is the selector on the westie remote i have where it sits onto the connection rod on the
gearbox.
Is your plastic saddle like part ok ? if its worn i've heard it can be a problem.
posted on 9/5/05 at 09:41 PM |
i mean the main cover, near the front
ady8077
posted on 9/5/05 at 09:57 PM |
Thanks Bob i'll check
JoelP I was afraid you ment that cover, i cant get to it with the box fitted
Adrian
posted on 9/5/05 at 10:05 PM |
the joy of building a mutant long car - mine beside my knee! (not quite)
Bart69
posted on 9/5/05 at 11:23 PM |
quote: Originally posted by ady8077
Hi
It sound like the synchromesh on its way out and probably worse i,m afraid.
graham
Adrian
MkIndy7
posted on 10/5/05 at 06:02 PM |
As a reply to some gears being hard to select with remotes .
If you try and use a really small gaitor, (eg. ours is a cobra hoop ring)
Then sometimes the remote can catch on the sides of this making gears hard to select,
or if you make too small a hole in the transmission tunnel top cos it can travel a suprising distance
