Author: Subject: Fuel tanks
scutter
posted on 22/6/05 at 06:58 PM Reply With Quote
Fuel tanks
In the search for a new fuel tanks, does anyone have a picture of a GTS tank pref the 8 gal job.
Many thanks Dan.
tom_loughlin
posted on 28/6/05 at 11:30 AM Reply With Quote
heres a pic of mine, think it 6gal though.
ned
posted on 28/6/05 at 11:57 AM Reply With Quote
mine looked just lke that, but i don't have any good pics of it.
I had issues with it fitting my car as darren's design uses 3mm plate i think for the rear upright bits behind the rear panel, i'd used 3/4" round it because of this i had to return it. worth checking imho.
Ned.
beware, I've got yellow skin
theconrodkid
posted on 28/6/05 at 12:39 PM Reply With Quote
dan,the weight of fuel really upsets the handling,best to go for a smaller tank,4 gallons will get you 100 miles,after wich you will want to stop for a break anyhow
who cares who wins
pass the pork pies
BKLOCO
posted on 2/9/05 at 04:48 PM Reply With Quote
Tom, Is that the outlet from the tank on the rear left that I can see in your photo? If it is then the tank has been made wrongly. Mine was the same. The outlet should be on the front of the tank on the right. If you look carefully you will see that the tank is baffled internally 1/3 of the way along from the filler end. The take off should be in this section. The position of yours will mean the fuel can slop about in 2/3 of the tank and the hose will be sticking out of the rear panel!! I have returned my tank to the workshop and am awaiting Darren's comments on his return from holiday. I think the fabricator is either reading the drawings wrongly or the drawings are wrong from Darren, which would be unusual.
All the best
Brian
stevebubs
posted on 2/9/05 at 04:57 PM Reply With Quote
Or only half fill it?
I've put a 50+litre ali tank into my fury so that if I need to go long distance, I don't have to worry about finding a petrol station.
Means my fury probably has a longer range (using sensible driving) than most daily drivers!
BTW For Fuel tanks, I'd go to Alifabs every time.
http://www.alifab.co.uk/
Custom tanks at reasonable prices. My 50gallon beast to custom design was only around the £120 (a tank for a locost should be quite a bit cheaper) which compares favourably with many off the shelf solutions.
PS He does have a "standard" tank designed for a locost, too if you don't want the hassle of designing your own
[Edited on 2/9/05 by stevebubs]
posted on 2/9/05 at 05:06 PM Reply With Quote
Or Allyfab
Tanks made to your spec
fastenuff
posted on 3/9/05 at 05:19 AM Reply With Quote
in my archive are some photo's of a gts fuel tank. Different fron those posted already
Ingmar
andyace
posted on 3/9/05 at 07:31 AM Reply With Quote
GTS Plastic Fuel Tanks
GTS also do a 6 and 8 gallon plastic fuel tank, pics in the chassis section on their web site. £80/£85
