Author: Subject: Anyone recognise this bulb holder?
RazMan
posted on 27/10/05 at 10:09 AM Reply With Quote
I am looking for a couple of these...
Raz
RazMan
posted on 27/10/05 at 10:10 AM Reply With Quote
Anyone know where I can get some? They are commonly used in aftermarket light units so they must be available somewhere
[Edited on 27-10-05 by RazMan]
Raz
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Location Born, Holland
Member Is Offline
Photo Archive Go!
Building: Locost-clone, powered by zetec 1.8, sierra type N9
posted on 27/10/05 at 11:17 AM Reply With Quote
Must be something Japanese (honda, toyota, nissan).
Greetz, Rob
Sex, drugs and Supersevens
omega 24 v6
posted on 27/10/05 at 11:41 AM Reply With Quote
do u need the wholr thing or just the b.c. bulb holder.
Is it an offset pin bulb as there are 3 wires going in but only two pins showing.
[Edited on 27/10/05 by omega 24 v6]
posted on 27/10/05 at 01:44 PM Reply With Quote
Hi-low beam in single bulb or brake/tail light. The third wire (black) is a common earth.
I'd say brake/tail light holder.
posted on 27/10/05 at 03:16 PM Reply With Quote
It's same as the rear light bulb holders in my Honda Revere.
RazMan
posted on 27/10/05 at 05:29 PM Reply With Quote
Sorry guys, I posted that in a bit of a rush. It is from a Lexus type aftermarket rear light assembly I bought on Ebay. I want to convert the fog lights to be another pair of stop & tail (the more lights I have the better visibility) I am fitting a separate fog light for legality's sake.
Peteff - Are you sure? A Honda part sounds too easy
Raz
omega 24 v6
posted on 27/10/05 at 06:19 PM Reply With Quote
the bulbholder part of your photo is very very similar to what can be found in rubbolite marker lights type 50 and 51 models. It is available in scc and sbc format but i'm not sure about offset pin format.
If you can remove the centre section bulbholder part and replace it with the rubbolite one then you could solve your problem.
u2u me for more
posted on 27/10/05 at 07:11 PM Reply With Quote
I can't see all of the fitting on yours, the Honda one has three lugs, one a bit larger than the other two so it can only fit one way round.
Triton
posted on 27/10/05 at 10:21 PM Reply With Quote
I would say that was Brian
www.tritonraceseats.com
www.hairyhedgehog.com
RazMan
posted on 28/10/05 at 08:43 AM Reply With Quote
Ok, I'll bite ......... so where can I find Brian the bulbholder then?
Have you been sniffing that resin again Triton?
[Edited on 29-10-05 by RazMan]
Raz
The Shootist
posted on 28/10/05 at 05:41 PM Reply With Quote
Lexus is Toyota
Lexies are built by Toyota so I'd try a Toyo part 1st.
phelpsa
posted on 28/10/05 at 05:54 PM Reply With Quote
Iv got a pair of those sat next to me at this very moment! Don't know where you can buy them though.
Adam
RazMan
posted on 29/10/05 at 09:58 AM Reply With Quote
but ... but ....
Would some beer vouchers pusuadw you to part with them ...... hmmmm?
Raz
RazMan
posted on 29/10/05 at 10:01 AM Reply With Quote
But these lights are just the 'look alike' jobbies that you see on every other Corsa, Clio, Fiesta etc etc. Probably made in China. They look great on my car though
Raz
