Author: Subject: chain differential
daz
posted on 14/11/05 at 10:37 AM Reply With Quote
chain differential
thought a cheap project would be to get an old mini and put a motorbike engine in even if it looks a wreck is just a bit of fun
are chain differentials available? or would my best bet to mount the engine sideways just behind the front seats connected directly to the prop shaft?
smart51
posted on 14/11/05 at 10:40 AM Reply With Quote
look at the sylva r1ot. It has the diff out of a fiesta with a chain ring bolted on where the crown wheel used to be.
Howlor
posted on 14/11/05 at 10:50 AM Reply With Quote
Mini's don't have a prop as they are front wheel drive but if you take a look at the Z-cars website they are experts at this. They will give you plenty of help. The other route to try is to go along to a grasstrack meet as it is a popular choice for those grassers out there!
daz
posted on 14/11/05 at 10:55 AM Reply With Quote
cheers, ill check out the zcars mini build DVD aswell, looks like there alot more work involved than i first thought but should all be possible
JC
posted on 14/11/05 at 11:13 AM Reply With Quote
Is it not possible to use the Mini diff with a sprocket bolted on a la berkley? Bike engine then mounts transversly at the front? You might shred a few diffs I suppose, but cheap as chips?
daz
posted on 14/11/05 at 11:32 AM Reply With Quote
whats a la berkley?
Kissy
posted on 14/11/05 at 12:14 PM Reply With Quote
Jedi s/seat hillclimb/sprint/circuit cars use a chain drive mini diff; cannot find a website, contacts below:
Frazer / John Corbyn - Jedi Racing Cars. Tel: 01933 440774 Fax: 01933 442008
Jedi Racing Cars Ltd. Nettlebush, Finedon Road, Wellingborough, Northants, NN8 4NY. UK
andrew.carwithen
posted on 15/11/05 at 03:52 PM Reply With Quote
Check out ebay item no. 4590502375
(ntdwm)
Could be just what you're looking for!..
Andy.
