Author: Subject: Help with wall fixings??
rayward
posted on 16/11/05 at 09:11 PM Reply With Quote
does anyone know what type of fixings i need to hang wall cupboards on a strawboard wall(made by stramit or karphos) tried contacting the company who made them but they dont deal with the stuff anymore he just said "its like a helicoil" HELP!!!
cheers
Ray
Deckman001
posted on 16/11/05 at 09:13 PM Reply With Quote
If it's a helicoil type fixing rq'd, try plater board fixings they look similar
Jason
Avoneer
posted on 16/11/05 at 09:28 PM Reply With Quote
If the walls hollow behind, the grey rawl plugs for plaster board should be fine.
You trying to earn garage time???
Pat...
zilspeed
posted on 16/11/05 at 09:30 PM Reply With Quote
If the wall has studs with the fibrous sheets on it, and you want a decent fixing for the cabinets, consider cutting out a slot of the material and housing in a section of timber. (i.e. housed into the studs as well). That's how I mount wall cabinets / central heating boilers etc...
Something like 3"x2"
I have never ever trusted anything that says it will carry a load directly onto a sheet. Sorry - I just don't believe it, especially considering the load a cabinet carries.
posted on 16/11/05 at 09:35 PM Reply With Quote
ive used plasterboard/hollow wall fittings in many kitchen and nothings ever fallen down! Ray, does it have plasterboard over the straw? Ive only worked with straw walls once, nearly a year ago now, cant remember what the surface is, except that it falls apart when you try to take tiles off!
Mark Allanson
posted on 16/11/05 at 09:41 PM Reply With Quote
Is this what they mean?
rayward
posted on 16/11/05 at 10:15 PM Reply With Quote
thanks for the replies.
yes Pat "trying" to earn garage time, doesn;t seem to be working though
the straw doesn't have plasterboard over it just a cardboard type covering and layer of skim plaster.
had lloked at that type of fastener, but not sure it will do the job as you said, the cupboards weigh in at 12kg and 18kg before the wife rams them full of stuff.
looks like i'll have to drill right through and put a recessed spreader plate on the other side of the wall, more bloody painting to do.
Ray
posted on 16/11/05 at 10:35 PM Reply With Quote
the wall should still have timber in it somewhere. Id locate this, (small drill bit is one way, watching out for wires) and screw a piece of timber to the surface, above the line of the units. Then secure wall brackets, hang the units and use rightangle brackets to further secure them to the beam you added. If you tile, this will further support them
Volvorsport
posted on 16/11/05 at 10:43 PM Reply With Quote
those turbo fix pictured above should do the job , they are used to hold radiators up and alsorts , once you get a few in should be ok
www.dbsmotorsport.co.uk
getting dirty under a bus
omega 24 v6
posted on 16/11/05 at 10:47 PM Reply With Quote
Just do it as zilspeed says you know it makes sense. If you can put your fist through a sheet of plasterboard or similar how do you expect a piddly little rawplug or similar to hold. If the fixed item falls off and makes a hole/breaks swmbo precious items then garage time will either be
a) banned totally while you make amends
or
b) plentifull in order to stay out of her way
Right said Zebidee I'm off to bed
Chippy
posted on 17/11/05 at 12:30 AM Reply With Quote
Stramit (Straw board)
This is a real pain to get a fixing in, they used to make a corkscrew type fixing which was just about good enough to hang a picture rail on, (and they sometimes fell down). The ONLY way to get a secure fixing, (from experience), is to batten the reverse side of the wall, and fix right the way through, not good if the lounge is the other side. Best of luck.
JonBowden
posted on 17/11/05 at 08:56 AM Reply With Quote
First of all find the wooden uprights (try bashing the wall with your hand to find the dull noise where the wooden uprights are). Make use of these for some of the fastenings. Then use plasterboard fastenings for the rest. I have mounted many big heavy rediators that way - none have come loose yet.
Oh, one tip. when you screw in the plasterboard screws, put a little PVA glue in the thread, this will reinforce the hole through the wallboard making it less likely to work loose over time
Jon
