givemethebighammer
posted on 26/11/05 at 10:43 PM |
dB killer - anyone tried one ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=8017707824&fromMakeTrack=true
seems a cheap way to reduce the exhaust noise for track days. I know its for a m/bike but should work on a car ?
welderman
posted on 26/11/05 at 10:45 PM |
Ye worked a treet, 104db to 98db for sva
Thank's, Joe
I don't stalk people
givemethebighammer
posted on 26/11/05 at 10:49 PM |
Did it really reduce the power of the car. I need to get from 99dB to under 98dB - 96dB to get on (and not get kicked off) most UK circuits.
Which type did you use ?
Wadders
posted on 26/11/05 at 11:26 PM |
Dont waste your money, you may as well shove a potato up the exhaust, it will have the same effect, the engine will be quiet but very underpowered and
very hot. best trade off iv'e found for power/noise is a standard bike can.
Al.
dl_peabody
posted on 26/11/05 at 11:53 PM |
The good part about the potato is where ever you go you can have chips
trikerneil
posted on 27/11/05 at 06:05 AM |
They've been known for years as mutes in the bike world. I added THIRTY mph to my Harley Trike by removing them and retuning the carb to suit.
Only use if desperate.
wilkingj
posted on 27/11/05 at 08:36 AM |
How do you get it past the 90 degree bend?.
Or does it fit inside from the other end, ie its a Can on/off job every time you remove it.
Sounds a bind, and probably reduces power.
Best Regards
Geoff
http://www.v8viento.co.uk
Guinness
posted on 27/11/05 at 09:19 AM |
I've got one spare. Used once (to get from 104db to 100.5db for the SVA and then it fell out). Sat on a shelf now.
It is a can off job each time you want to put it in.
Mike
daz
posted on 27/11/05 at 11:01 AM |
looks more like a sex toy
carnut
posted on 27/11/05 at 01:50 PM |
I bought one from a chap at a donnington trackday when my car was 104dB and needed to be 98dB. It took it down to 97dB. I think there good for a
quick fix but not the best as you do loose power.
posted on 27/11/05 at 02:53 PM |
its two inches round man! imagine the damage that could do!
