New Topic New Reply
Author: Subject: First fire up.
stuey39
posted on 9/12/05 at 04:25 PM Reply With Quote
First fire up.
Good day today on my Indy build. Finally got everything connected, turned the key, a few splutters and away she fired. Did notice that the exhaust was glowing red after only a few mins, is this right?
Stuart.
colibriman
posted on 9/12/05 at 04:31 PM Reply With Quote
sounds too lean...so not good really - you could burn a piston. richen up your carb/carbs
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
tks
posted on 9/12/05 at 04:37 PM Reply With Quote
yeah..
To lean or fireing timing not good...
how well does it runs idle?
escapes should become 300degrees near the head..
Tks
Spriggsy
If it's glowing red on idle the igntion timing could be to far retarded-or is it advanced, can't remember which way round, but not set right anyway.
John.
gary gsx
posted on 9/12/05 at 06:59 PM Reply With Quote
To Lean a mixture and/or timing retarded
stuey39
posted on 9/12/05 at 07:12 PM Reply With Quote
I think I set the initial timing at 6 degrees and as I dont have a timming light yet what way should I turn the dizzy? This is on a 2lt pinto with mild road cam.
Stuart
Spriggsy
posted on 9/12/05 at 10:49 PM Reply With Quote
Remove dizzy cap and spin engine on key, note which way rotor arm spins. Then loosen dizzy and turn same way(off top of my head think it's clockwise) to advance timing. Think thats right.
If you are running a performance cam with a vernier power pulley this might explain why your original setting could be wrong.
John.
Chippy
posted on 9/12/05 at 11:02 PM Reply With Quote
No, to advance the timing turn the opposite way to running rotation, turning it the same way will retard the timing even more.
Spriggsy
posted on 9/12/05 at 11:09 PM Reply With Quote
Quite right Chippy, I stand corrected- It's been a long day!
John.
stuey39
posted on 10/12/05 at 08:44 AM Reply With Quote
Re
Thanks everyone for your comments.
Stuart
New Topic New Reply
