Author: Subject: How much to spray a Locost???
pathfinder
posted on 17/12/05 at 04:23 PM Reply With Quote
I want the bodywork on my velocity to match the powder coat and it doesn’t look as if I will get a good match in g.r.p. Does anyone have a rough idea of how much it would cost to get professionally sprayed???
Is there anything specific that I should be asking for when getting quotes???
Cheers chaps
pathfinder
posted on 17/12/05 at 04:57 PM Reply With Quote
www.zx12tiger.com this looks like a neat job!!!
Have they had the panels sprayed first and then fitted them or do they use loads of masking tape???
Bob C
posted on 17/12/05 at 05:01 PM Reply With Quote
I got mine done in stoke for £400, etch prime, stone guard underneath & matched my gelcoat in 2pack pretty nicely.
I'd already sprayed the steelwork in primer to stop it rusting while I nailed on the aluminium.
Note - one thing I should have doen before spraying was weld on some m6 bolts for earthing electrics... ah well, live & learn
Bob
steve_gus
posted on 17/12/05 at 05:33 PM Reply With Quote
ask mark allanson on this site - he worked in a repair shop and has also worked in body refinishing
atb
steve
ps - its unlikely to be cheap - just getting the painted bits of a motorbike done costs 350+
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
James
posted on 17/12/05 at 06:32 PM Reply With Quote
Cheers chaps
Powder coat of the chassis?
You don't really see a lot of chassis unless the bonnet's off once the car's built. You sure it's worth it?
James
posted on 18/12/05 at 11:03 AM Reply With Quote
A year or so ago I was told to estimate around £100 per panel - so the ali bits on my car would be around £400 (2 sides, bonnet, rear panel), which matches what people have said above.
I'd guess that the GRP bits may be cheaper, if you remove them from the car - they can be lined up together in the spray booth and done in one go.
This is all guesswork, BTW!
rgds,
Mark Allanson
posted on 18/12/05 at 11:32 AM Reply With Quote
atb
steve
atb
steve
I wouldn't touch one for less that £800+vat
Hugh Paterson
posted on 18/12/05 at 10:37 PM Reply With Quote
Cost of painting
Christ Mark I see a radiator roller and a Tin of Dulux weathershield getting thrown at my car
Shug
iank
posted on 18/12/05 at 11:52 PM Reply With Quote
His Ron'ness mentions a rattlecan paint job looking good in the book of obvious optimism.
Can of NATO green from an army surplus and a brush?
Viper
posted on 19/12/05 at 07:15 AM Reply With Quote
I have been quoted between £800 & £1000, that is to sort out the atrocious bodywork of my Avon along with the paint, these prices were on the cheaper side, just for me, because of the amount of work we put there way.
zzrpowerd-locost
posted on 19/12/05 at 12:18 PM Reply With Quote
At all those quotes
New panels shouldnt cost as much as old ones to paint, cos there aint the prep work!
My mate has a spray shop, makes most his money on insurance jobs, so can afford to discount private jobs, for mates
And he dont do half a job cos its cheap! Its still an advert for him! Charging me £150 to spray the panels on my bike! Recons £300 - £400 should see a new kit done depending on colour, what to be sprayed ect ect
Volvorsport
posted on 19/12/05 at 01:04 PM Reply With Quote
well , at 300 thats almost just the cost of materials to spray it decently .
even with new panels , theres always preparation to do .
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 19/12/05 at 02:09 PM Reply With Quote
I plan to pain mine myself; got the kit, done it before so know I can get a decent finish.
... but has anyone tried to spay using ,the photochromatic paint (you know the stuff, that looks two different coloours depnding on where you view it from)
e.g. .. try to see past the foreground!!
at £300 per litre seems a lot to risk making a balls up of it.
posted on 19/12/05 at 02:19 PM Reply With Quote
Sit her in the car and nobody will notice your paint . I don't like the flip paints actually, 3 different colours and all insipid from most angles. Most of the cars you see them on are worth less than the paint. I know someone who picked some up cheap as it was a cancelled order which the shop had already mixed.
posted on 19/12/05 at 02:52 PM Reply With Quote
that is a bad idea as she would be too distracting unless she puts on undergarments.... but what about DIY spraying with this paint? doable or an expensive mistake?
posted on 19/12/05 at 04:44 PM Reply With Quote
He painted a bike tank and fairing with it using a gravity feed gun and it came out quite well.
PaulBuz
posted on 19/12/05 at 05:36 PM Reply With Quote
I would'nt even consider spraying a flip paint at home, As I understand it, & Mark will no doubt say, this stuff is dependant on the film thickness to get an even effect.
I did spray my car in my garage, but it was a bit of a pain. It turned out okay in the end, but it is more work than you think!
Paul
