Author: Subject: Hammerite Stone chip paint - will it stick to aluminium ?
givemethebighammer
posted on 19/1/06 at 11:17 PM Reply With Quote
I'm just finishing a panel to box in the underside of the rear of my tiger. You can see some of it when standing behind the car so I want to paint it black as the aluminium will soon tarnish and look crap.
I found an aerosol of the above on the shelf in the garage. So I found a piece of scrap piece ali, gave the surface a good key with wire wool and cleaned it off with acetone. The paint seems to have gone on OK but the question is will it stay put ? Rescued attachment stonechip_products.jpg
Chippy
posted on 20/1/06 at 12:11 AM Reply With Quote
The only way to get any paint to stick to alloy, is to apply alloy self etching primer first. About £11 per spray can IIRC.
posted on 20/1/06 at 12:29 AM Reply With Quote
It's underneath at the back who's going to see it and the aluminium's not going to rot if it cracks, save yourself £11 and whack it on thick
UncleFista
posted on 20/1/06 at 02:13 AM Reply With Quote
Hammerite do a primer called "Special metal primer" or something along those lines.
It's for painting ally before overpainting with Hammerite/smoothrite it doesn't stick properly without...
Edited to say; ah crap, I didn't read properly, didn't realise you were on about stone chip stuff....
[Edited on 20/1/06 by UncleFista]
Tony Bond / UncleFista
Danozeman
posted on 20/1/06 at 09:49 AM Reply With Quote
what about underseal. No ones gonna see it.
Dan
posted on 20/1/06 at 11:33 AM Reply With Quote
in that case leave it as it is; why weigh yourself down?
givemethebighammer
posted on 20/1/06 at 02:50 PM Reply With Quote
that's the point - You can see some of it ! That's why I want to paint it black
I think as Pete says if I spray it on in a thick coat, it won't matter if it cracks a little.
DarrenW
posted on 20/1/06 at 03:29 PM Reply With Quote
I used smoothrite spray on a load of bits i had de-rusted. Used etch primer first (approx £8 per tin). Defo worth it imho. Saves doing the job again later.
Avoneer
posted on 21/1/06 at 10:16 AM Reply With Quote
Yes it will.
I sprayed my rear valance in this, straight onto the ali.
Also did my roll bar, cockpit side trims, mirrors, screen uprights etc. in this and it looked fine.
Pat...
