Author: Subject: Bike Tacho
dave1888
posted on 28/1/06 at 09:02 AM Reply With Quote
Bike Tacho
Got myself a speedo/tacho from a kawazaki kle500. If i remember right they are a twin cylinder will the tacho still work in a cec Rescued attachment clocks.jpg
Guinness
posted on 28/1/06 at 09:57 AM Reply With Quote
I guess it depends what engine / ignition you are running.
If you are running sequential distributor ignition then I don't think so. If you are using wasted spark ignition then it should be OK?
Only one way to find out for certain, hook it up!
HTH Mike
(P.S. Have hangover, take no notice of anything I suggest)
MikeR
posted on 28/1/06 at 11:14 AM Reply With Quote
don't try taking it up to the red line in a cec though or it might become an ex-cec!
(another helpful post by the really useful posting society)
dave1888
posted on 28/1/06 at 01:48 PM Reply With Quote
Im using megajolt ignition system on a zetec engine.
Bob C
posted on 28/1/06 at 05:38 PM Reply With Quote
Just one note of caution - a bike tacho might be expecting a clean 12V signal from a CDI unit, so may not survive the experience of being wired to LT coil terminals (these see transients of several hundred volts). Maybe your megajolt has a clean 12V tacho output?
cheers
Bob
Ronin
posted on 28/1/06 at 05:40 PM Reply With Quote
The megajoly uses Ford's wasted spark system from an EDIS module so you may be in luck.
paulf
posted on 28/1/06 at 08:13 PM Reply With Quote
The V3 megajolt has a 12v tacho output that should work , the edis tacho or idm output may also be an option.
How is the speedo driven is it electronic or mechanical?
Paul.
