Author: Subject: Fuel Tank for Avon
Ian D
posted on 18/2/06 at 06:45 PM Reply With Quote
Fuel Tank for Avon
[img]http://my pictures/2006-02-18/fuel tank[/img]
[img]http://my picture/2006-02-18/fuel tank 2[/img]
Can anyone help please. My Tiger Supplied tank fits as per the picture with the welded brackets. Is it me or have I the wrong tank. Also the the feed and return pipes foul the diagonal rear strut.
I have also supplied a picture with the bottom of the htank parallel with the botton of the chasis which is what the book shows.
k33ts
posted on 18/2/06 at 06:52 PM Reply With Quote
pictures not working
Ian D
posted on 18/2/06 at 07:46 PM Reply With Quote
Ive put my picture in the photo album
under IanD
Sorry about the cock up.
Ian D
posted on 18/2/06 at 07:55 PM Reply With Quote
mat.price
posted on 18/2/06 at 08:35 PM Reply With Quote
i have just put a pic in my photo archive not the best but will try and find more if it help?
mangogrooveworkshop
posted on 19/2/06 at 12:57 AM Reply With Quote
[img][/img]
Northy
posted on 19/2/06 at 10:45 AM Reply With Quote
I think they've given you the wrong tank, it should sit like the bottom picture.
G
Graham
DaveFJ
posted on 20/2/06 at 09:21 AM Reply With Quote
Just cut the mounting tabs off and make up some straps to mount it how you need....
It's generally agreed on here that it's better to mount the tank with straps padded with rubber anyway. There is a worry that the welded mounting lugs will lead to cracking.....
Dave
Viper
posted on 20/2/06 at 06:09 PM Reply With Quote
Heres how i have fitted mine
johns
posted on 30/4/06 at 06:36 AM Reply With Quote
hi Ian did you find a solution. I have the same problem and would much appreciate any advice. Think its down to using the injection tank as there's not enough clearance for pick up and return stubs
Ta
John
