russbost
posted on 25/2/06 at 05:36 PM |
Renault Laguna Xenon HID headlamps
Does anyone know anything about the Renault Xenon HID gas discharge headlemps. I've got one packed up & it's not the bulb &
it's not the fuse (unless they've hidden one somewhere they don't tell you). I take it the unit on the back of the lamp is a
transformer? Am I looking for a 12volt feed up to that point?
Any info would be useful Bl***y stupid system, a failed headlamp used to be a 5 minute job whatever the cause, took me half an hour just to get access
- I hate modern cars!
Snuggs
posted on 25/2/06 at 06:40 PM |
IIRC the bulbs are 100v so will be powered from a transformer.
This should be a 12 v supply.
Dont know if there is a hidden fuse anywhere.
I was told that the bulbs are £120 each from Renault
[Edited on 25/2/06 by Snuggs]
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
theconrodkid
posted on 25/2/06 at 08:06 PM |
there was something about these on piston heads some time ago,worth an ask?
who cares who wins
pass the pork pies
posted on 25/2/06 at 08:43 PM |
I had a search on some of the usual forums for you nothing specific -- may be something but lost in the usual deluge french car electrical
problems.
I should have info on the system that was used by Rover on the 75.
russbost
posted on 25/2/06 at 08:49 PM |
Guess they all use similar systems, voltages etc, what can you give me on the Rover system?
Thanx for the efforts so far guys!
posted on 25/2/06 at 09:12 PM |
Sorry -- the Rover Rave manual seems to ignore headamps.
steve_gus
posted on 25/2/06 at 11:37 PM |
have a look on the parkers car forum
http://www.parkers.co.uk
i think its usually the ballast or a bad connection
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
russbost
posted on 27/2/06 at 10:32 PM |
Thanx for the info Steve, have posted on Parker's so far with no joy - can't believe I'm the only person to have had this problem
steve_gus
posted on 28/2/06 at 07:54 PM |
im amazed that a guy called antmat hasnt replied to you ---- hes got about 14k posts!!!! all of them slagging off renaults. if ever someone needed a
life
atb
steve
russbost
posted on 28/2/06 at 10:27 PM |
Have now had a load of info from a guy called Andi on the Parkers site - likely to be the ballast module located under the headlamp & prone to
water ingress, I suspect the headlamp was full of water due to an idiot with a pressure washer so would make sense.
Anyway an answer has been got which is good - proves these forums work.
Thanx,
Russ
