Author: Subject: engine placement
ADD
posted on 1/3/06 at 06:08 PM Reply With Quote
engine placement
HI All,
Just a quick bit of re-assurance please. I am going roughly by the tiger avon dimentions in builing my own chassis and have gotten to placing engine and box. I have done some mods and am managing to fit them alot futher back than tiger specify. I am wondering if its going to be OK before I go to much further. I cant see any problem but Im not 100% sure about it. Constructive comments welcomed as always.
donut
posted on 1/3/06 at 06:11 PM Reply With Quote
Have you done the footwells yet? Make sure you have enough room for your feet & pedals.
gary gsx
posted on 1/3/06 at 06:21 PM Reply With Quote
Thats how far ive got mine back but like Donut says mind the footwells as they get a tad small, im going to grind a bit of the starter motor case on the gearbox away as starter doesnt go in that far so your get a bit more room in passengers side
posted on 1/3/06 at 06:22 PM Reply With Quote
Mine's about like that in the locost chassis. I made the tunnel after I placed the engine and box and it puts the gearlever in a better position as well. There's lots of room on the passenger side, their legs don't go anywhere near the end of it.
[Edited on 1/3/06 by Peteff]
ADD
posted on 1/3/06 at 06:23 PM Reply With Quote
Not done the foot wells yet. Its going to be a bit cramped. I cant find any problem with SVA just for the peddles being close together unless anyone knows different..........
lsdweb
posted on 1/3/06 at 06:56 PM Reply With Quote
I think this is about your limit.
Wyn
gary gsx
posted on 1/3/06 at 07:01 PM Reply With Quote
Thats tight
Humbug
posted on 1/3/06 at 07:07 PM Reply With Quote
Make sure there is enough room for the clutch release arm...
posted on 1/3/06 at 07:17 PM Reply With Quote
i once put an engine so far back that the exhaust had to go forward to clear the mastercylinder
Id always allow a few inches extra for the pedals, once you settle in and start moving you feet you will probably decide you need a little more space!
pewe
posted on 1/3/06 at 07:27 PM Reply With Quote
Don't know how /where the following will run but make sure you consider steering column run, battery and master cylinder location, prop shaft length. Good luck, Pewe.
Mark Allanson
posted on 1/3/06 at 07:29 PM Reply With Quote
Make sure that the rear end of the gearbox doesn't coincide with any transmission tunnel uprights or you will struggle with brake/fuel pipes and loom. The width of the figure 8 end of the box is about 15mm narrower than a book tunnel internal measurement.
posted on 1/3/06 at 09:05 PM Reply With Quote
I'll need to check but I am prettuy sure I read there is some minimum spacing between pedals.... will check this one.
posted on 1/3/06 at 09:30 PM Reply With Quote
Quite a few very significant differences from the book chassis -- no quick answer.
posted on 1/3/06 at 10:08 PM Reply With Quote
This is where mine is
Engine position
Engine position
As said before leave room for the clutch arm and build the tunnel round the box so you can get the reverse switch in etc. If you don't drive in rigger boots there will be room for your feet. Moving it further back helps with the alternator as it is in a wider part of the engine bay, I just fitted a shorter belt and the column clears it better as well.
bimbleuk
posted on 2/3/06 at 09:37 AM Reply With Quote
All I can add is think about access for servicing or maintenance.
If for example you were to remove the engine but leave the GBX in situ. Can you access the bolts for this?
posted on 2/3/06 at 10:57 AM Reply With Quote
I can undo the bolts on mine and lift it out or drop it and lift the car off of it no problem but it's easier to take it out with the box so you don't have to line it up on the splines to refit it.
jon_boy
posted on 2/3/06 at 11:12 AM Reply With Quote
there must be a minimum distance apart for pedals as they can fail an mot for it if you change the pedals to new ones and put em in the wrong place. think its about 30mm between each..
posted on 2/3/06 at 11:57 AM Reply With Quote
I had quick scan in SVA book but could not find it; I am sure I have seen the spec. as it got me worried that mine are too close together. Must look harder.
