cryoman1965
posted on 17/3/06 at 06:07 PM |
Amazing
I knew nothing about cars 1 year ago. Today i fired up my Pinto powered Indy, fitted with gsxr 600 carbs and a home made manifold. After a few
mins of trying, and fault finding, tweaked the dizzy cap slightly (cheers Keith) and away she went. Brilliant Feeling. ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
stevec
posted on 17/3/06 at 06:23 PM |
Great stuff. Its a really good stage to get to and a relief.
Steve.
cryoman1965
posted on 17/3/06 at 06:39 PM |
quote: Originally posted by robocog
Should I bring my timing light to the next meet ?
Thanks but Keith has one.
R1minimagic
posted on 17/3/06 at 07:42 PM |
SteveC
Why have u got an avatar with a marine engine??? lol
posted on 17/3/06 at 08:52 PM |
Nice one Nige
Have you got a completion date in sight yet?
Nick
DEAN C.
posted on 18/3/06 at 11:22 AM |
Have you got a completion date in sight yet? (Nick205)
You should know by now,completion dates come and go!![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Had my Indy on a trackday trial run in Nov.2004 and I'm still messing with it.in fact its in bits again.
[Edited on 18/3/06 by DEAN C.]
Once I've finished a project why do I start another?
cryoman1965
posted on 18/3/06 at 07:11 PM |
Nice one Nige
Nick
May (ish) this year or some time else, you set a date and it passes so i will see how it goes.
donut
posted on 18/3/06 at 10:07 PM |
I'll be at that point soon!!
EViS
posted on 24/3/06 at 06:55 PM |
I notice you say 'homemade' manifold. As i'm in the same position as you seem to have been 1 year ago, i'm currently going
through the learning process .
How did you make your manifolds?
What tools did you use?
How much did the manifold build cost?
How long did they take to complete?
How easy was it to fit an exhaust on them?
cryoman1965
posted on 24/3/06 at 10:35 PM |
quote: Originally posted by EViS
I notice you say 'homemade' manifold. As i'm in the same position as you seem to have been 1 year ago, i'm currently going through
1. Had plate Lazer cut in 5mm stainless.£20. 4x 38.1mm bent tube (free)
2.None
3.£20, the tig welding was free
4.5 weeks, source pieces arrange free weld.
5.Exhaust ?
[Edited on 24/3/06 by cryoman1965]
![](/galpreviews/a344628-Manifold Complete 003.jpg) ![Rescued attachment Manifold Complete 003.jpg](/gallery/a344628-Manifold Complete 003.jpg) Rescued attachment Manifold Complete 003.jpg
cryoman1965
posted on 24/3/06 at 10:38 PM |
another
![](/galpreviews/a344631-Manifold Complete 006.jpg) ![Rescued attachment Manifold Complete 006.jpg](/gallery/a344631-Manifold Complete 006.jpg) Rescued attachment Manifold Complete 006.jpg
EViS
posted on 25/3/06 at 12:59 PM |
I say exhaust... as I thought the manifolds were also the (much longer) tubes (exhausts) which flow to the outside of the car body (for which a hole
needs to be cut in the GRP - see below image)... how much do they cost to make then?
[Edited on 25/3/06 by EViS]
cryoman1965
posted on 25/3/06 at 03:13 PM |
Unless you have access to a hydraulic tube bender and are a very good tig welder i would buy one. I waited and bought one from someone doing an engine
change.
EViS
posted on 25/3/06 at 03:21 PM |
But again do these vary from engine to engine? Or do they all fit every engine (manifold)?
Also, does an engine from a donor not already have manifolds? Why would i need to pay for new ones?
cryoman1965
posted on 25/3/06 at 03:57 PM |
The manifold takes the exhaust straight out of the side of the car. Leaving space for steering rack,alternator master cylinder. Go along to a couple
of shows and look around at what is available. You can get some good deals at shows. Detling Show in Kent is on soon.
Manfolds turn up on LCB or flea bay from time to time when builders do an engine change. MK and Luego manifolds are exactly the same for the pinto
engines and may be for others.
[Edited on 25/3/06 by cryoman1965]
