donut
posted on 18/3/06 at 09:49 AM |
Do all sierras have type 9 box's?
Especially the CVH jobbies?
flak monkey
posted on 18/3/06 at 09:53 AM |
I believe that all sierras up to about 1988 were fitted with the T9. After that they switched to the MT75.
The only other box used in the sierra was the Type E and that was 4 speed.
Should be easy enough to tell if you stick your head under and have a look?
Sera
http://www.motosera.com
stevec
posted on 18/3/06 at 09:59 AM |
easiest way to spot is reverse on Mt75 is on the opposite side to type9.
donut
posted on 18/3/06 at 10:10 AM |
Great thanks
only asking as i have had an email from a confused chap looking for a donor and i wasn't 100% sure if ALL Sierras had type 9.
zilspeed
posted on 18/3/06 at 10:45 AM |
Remember - the MT75 has a ribbed case. That's another easy way to spot one amongst the grot of the scrappy.
Also bear in mind that not all type 9 boxes have the lighter removable bellhousing. Some have the pig iron integral one which ways a metric
sh£$load.
donut
posted on 18/3/06 at 11:10 AM |
sh£$load.
Sounds like the one i have!!
scotty g
posted on 18/3/06 at 05:12 PM |
All CVH sierras had type9 boxes
big_wasa
posted on 18/3/06 at 05:35 PM |
isnt it only the 2l dohc and the later 4x4 that have mt75 box?
EViS
posted on 20/3/06 at 09:40 PM |
Is there any significant reason why a type 9 is superior to the mt75? I've heard that the mt75 is slightly larger, why is this a problem?
I'd expect that, being the newer type it should be better...?
[Edited on 20/3/06 by EViS]
iank
posted on 20/3/06 at 09:46 PM |
MT75 is, as you say, bigger so the transmission tunnel will need to be made wider leaving less space for your feet/pedals.
It also has an integral bellhousing so isn't as easy to use for non-ford engines.
According to burton it was fitted to the following:
• Sierra 2wd 12/88 on
• Granada 2wd 12/88 on
• Sierra 2.9 XR4x4
• Sapphire/Escort Cosworth 4wd
• Granada 2.9 4x4
EViS
posted on 20/3/06 at 09:56 PM |
So if i was to use a sierra as the donor, would i need to find one made prior to 1988 in order to make sure i get the type 9 with it? But would there
be a problem with an engine/other parts of this age?
posted on 20/3/06 at 10:48 PM |
The MT75 will fit the Pinto, Zetec and CVH engines which are probably amongst the three most commonly used donor engines. It is a stronger gearbox
than the Type 9, so if you can mak the room in the transmission tunnel then by all means use it. If you want to use a non-Ford engine then the Type 9
is generaly a better bet.
