New Topic New Reply
Author: Subject: bike engines
ady77
posted on 31/3/06 at 08:19 PM Reply With Quote
bike engines
Hi all I am building a GTS locost and have decided to use a bike engine. What bike engine do you recommend? And what sort of price am I looking at paying for this engine?
Many thanks
Lightning
posted on 31/3/06 at 08:32 PM Reply With Quote
You are best using search or going back through the BEC threads as this has been discussed numerous times before.
billy
Honda firelade engines are quite cheap, good performance and cheap to run. ideal start me thinks
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
mark chandler
posted on 31/3/06 at 08:49 PM Reply With Quote
I,m building mine with an early 893 blade engine still good power with higher emmissions allowed for SVA as its a pre 93 lump.
A later engine will involve additional expense of CAT's etc.
These things keep their value so an upgrade at a later stage should not kill the bank.
Regards Mark
yorkshire-engines
posted on 31/3/06 at 09:02 PM Reply With Quote
bike engines
sent you a u2u
ask any member who has purchased from me there good condition guranteed motors
malc 07960011585
posted on 31/3/06 at 09:20 PM Reply With Quote
your budget determines the engine you use. Cheapest will be blade and zx9, if you source your own on the cheap you can have it fitted and running for £600, including a prop. R1 will be over a grand, zx12 aproaching 2k running, and busa more still.
New Topic New Reply
