tom court
posted on 7/4/06 at 04:26 PM |
problem with carbs
just been out for a run, now it will not tick over running at 2-3000 rpm
any ideas what i have broken???
running 2 ltr pinto twin 45 dellortos
![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif)
flak monkey
posted on 7/4/06 at 04:35 PM |
Start with the simple one...Has the accelerator cable got jammed meaning its not letting the butterflys close right up?
Sera
http://www.motosera.com
DIY Si
posted on 7/4/06 at 04:42 PM |
Chech the cable and the return spring. Is the cable old at all? If so, just take it prt if poss and spray the cable with a teflon grease. Did this 3
years ago, and haven't had a similar problem yet. Also check the choke cable if you have one.
Or you've buggered something else, but i doubt it.
tom court
posted on 7/4/06 at 06:02 PM |
cable seems ok and carbs seem fully closed?
DIY Si
posted on 7/4/06 at 06:09 PM |
seem closed? If you're not sure, wind the throttle stops/idle speed adjusters all the way out and see if the throttle arms come up against the
stops. Then you know they're shut.
tom court
posted on 7/4/06 at 06:21 PM |
done that seems to be fully closed although the last bit seemed a bit stiff????????????????
posted on 7/4/06 at 06:46 PM |
bent thingy through the carbs? Apparently having your return spring at one end only can bend them.
tom court
posted on 7/4/06 at 08:35 PM |
thay where fine today until i reved reel hard ? thought it was the cable but all seems fine. seems like fuel is still getting through?????????????
posted on 7/4/06 at 08:48 PM |
do you have a proper throttle stop?!
Marcus
posted on 7/4/06 at 09:01 PM |
Yup, sounds like a bent spindle
Marcus
Marcus
Because kits are for girls!!
tom court
posted on 7/4/06 at 09:43 PM |
what is the solution???
flak monkey
posted on 7/4/06 at 09:45 PM |
A new one most likely.
Things like that are precision items and you will never manage to straighten it.
However you should take the neccessary steps (as mentioned by Joel) to stop it happening again if it is the problem.
Sera
tom court
posted on 7/4/06 at 09:49 PM |
can it be replaced?
tom court
posted on 7/4/06 at 09:55 PM |
whaere do i get one and is it much of a job?
cheers tom
zilspeed
posted on 8/4/06 at 07:11 PM |
Defective misab plate on one or more chokes ?
Some have rubber components which have no problem collapsing inwards.
