Author: Subject: New Luego Velocity, Viento & Locost 2006 / 2007 Price List
Luego Sports Cars
posted on 13/4/06 at 03:57 PM Reply With Quote
Some prices have gone down!!!! No that just cant be! Yes it is TRUE!!
We have also increased our product range by over 100 new items, so nearly everything you will need you can get from the Luego Parts Department.
Most major credit cards accepted.
Luego Velocity, Viento & Locost Price List
All prices subject to P & P. Prices may change due to availability.
Code Luego Parts List Price Ex VAT Inc VAT
Running Gear Live Axle-Locost
A1 Bottom Wishbones Pair £85.00 £99.88
A2 Top Wishbones Pair £65.00 £76.38
A3 Chrome Top Wishbone Each £25.00 £29.38
A4 Chrome Bottom Wishbone Each £60.00 £70.50
A5 Panard Rod £30.00 £35.25
A6 Trailing Arms set of 4 £50.00 £58.75
A6 Suspension Set (4 Wishbones, 4 Trailing Arms, Panard Rod) £220.00 £258.50
A7 Poly Bush Set (36 Bushes halves, 18 Inserts) £41.00 £48.18
A8 Poly Bush Inserts 2 halves £1.00 £1.18
A9 Poly Bush Insert tube 1 off £0.75 £0.88
A10 Wishbone End Tube 1off DIY £0.70 £0.82
A11 Top Wishbone Balljoint Threaded End Tube pair DIY £7.00 £8.23
A12 Wishbone 19mm Tube DIY £4.80 £5.64
A13 Bottom Wishbone Balljoint Plate pair DIY £5.50 £6.46
A14 Bottom Wishbone Shock Plate pair DIY £5.50 £6.46
A15 Bottom Wishbone Pair (To Fit Sierra Uprights) £85.00 £99.88
A16 Aluminium Conversion Boss Pair (To Fit Sierra Uprights) £28.00 £32.90
A17 Nut & Bolt Set for Wishbones, Panard Rod & Trailing Arms £30.00 £35.25
Running Gear I.R.S-Velocity
B1 Bottom Wishbones Pair (rear) £110 £129.25
B2 Top Wishbones all 4 £135 £158.63
B3 Suspension Set (8 Wishbones, 2 Hub Carriers) Disc Or Drum £445 £522.88
B4 DIY Conversion Kit (4 rear Wishbones, 2 Hub Carriers, Diff Carrier) Disc Or Drum £490 £575.75
B5 Hub Carrier (pair) £140 £164.50
B6 Poly Bush Set (44 Bushes halves, 22 Inserts) £48.00 £56.40
B7 Nut & Bolt Set for the Wishbones & Diff Bolts IRS £30.00 £35.25
Shocks & Ball Joints
C1 Bottom Ball joint (each) £18.00 £21.15
C2 Top Ball joint (each) £9 £10.58
C3 Escort Track Rod Ends (each) £7 £7.64
C4 Shocks and springs (set of 4) £382 £448.85
C5 Springs x 2 1.9" & 2.25" (Most Lengths and ratings) £70 £82.25
Roll Bars
D1 Road Roll Bar and back stays Velocity M/Steel £110 £129.25
D2 Road Roll Bar and back stays Viento M/Steel £145 £170.38
D3 Race Roll Bar and back stays (CDS) Locost & Velocity £140 £164.50
D4 Race Roll Bar and back stays (CDS) Viento £160 £188.00
D5 Chrome Roll Bar Velocity £340 £399.50
D6 Chrome Roll Bar Viento £410 £481.75
D7 4 Point Harness Cross Bar Viento £60 £70.50
D8 4 Point Harness Cross Bar Locost & Velocity £55 £64.63
D9 St/St Roll Bar, 4 point & Back Stays Velocity £280 £329.00
D10 St/St Roll Bar, 4 Point & Back Stays Viento £310 £364.25
750MC Race Roll Cages & Side Impact Bars
DA1 750 MC Full 38mm Roll Cage with Side Impact £400 £470.00
DA2 750 Race Roll cage extensions (front hoop and back stays) Viento £250 £293.75
DA3 750 Race Roll cage extensions (front hoop and back stays) Locost & Velocity £185 £217.38
DA4 750 Full race Roll cage Viento £650 £763.75
DA5 750 Full race Roll cage Locost & Velocity £565.00 £663.88
DA6 Welding And Fabrication Costs Per Hour £40.00 £47.00
DA7 750 MC Side Impact Bar £100 £117.50
Steel Chassis-Velocity & Locost
E1 Locost-Live Axle (Cross Flow compatible, Brackets) £550.50 £646.84
E2 Locost-Live Axle (Cross Flow compatible, Brackets, Steel floor) £580.80 £682.44
E3 As above with aluminium floor £523.80 £615.47
E4 IRS Velocity Chassis, Brackets, Steel Floor £650 £763.75
E5 DIY Live Axle Kit £370 £434.75
E6 DIY I.R.S Kit £385.00 £452.38
E7 Powder Coat £185.00 £217.38
Brackets
F1 Axle Brackets (pair) £20 £23.50
F2 Trailing Arm Brackets (pair) £19.50 £22.91
F3 Suspension (standard) £3 £3.53
F4 Suspension (wide) £3 £3.53
F5 Live Axle Suspension Bracket Set (4 wide, 12 standard, axle and trailing arm) £87.50 £102.81
F6 Front Wing Stays (pair) £75 £88.13
F7 Cross Flow Engine Mounts (pair) £48 £56.40
F8 Pinto Engine Mounts (pair) £48 £56.40
F9 Toyota Engine Mounts (pair) £64 £75.20
F10 Z Tec Engine Mounts (pair) £48 £56.40
F11 Rover V 8 Engine Mounts (pair) £75 £88.13
F12 Engine Mount Rubbers (pair) £12 £14.10
F13 I.R.S Suspension Bracket Set (4 wide, 16 standard) £55 £64.63
F14 Front Cycle Wing Brackets Pair (To Fit Sierra Uprights) £92 £108.10
F15 Head Light Bracket £38.00 £44.65
Fuel Tanks & Catch Tanks & Battery Boxes
G1 Aluminium Road (6 Gallon) £160 £188.00
G2 Aluminium Road With Catch Pot (6 Gallon) £185 £217.38
G3 Aluminium Road VIENTO Fuel Tank (9 Gallon) £216 £253.80
G4 Aluminium Road Viento Fuel Tank With Catch Pot (9 Gallon) £182 £213.85
G5 Aluminium Race (2 Gallon) £115 £135.13
G6 Aluminium Oil Catch Tank (1ltr) £65 £76.38
G7 Aluminium Fuel Filler Dog Leg with Rubber Hose £40 £47.00
G8 Battery Box ( Ally) £35 £41.13
G9 Battery Box (Stainless) £45 £52.88
G10 Battery Box ( Brushed) £55 £64.63
Pedal Box, Brake Fittings, Cables & Handbrake
H1 Gold Package Cable (Master Cylinders, Bias Bar etc) £280 £329.00
H2 Standard Pedal Box Cable £100 £117.50
H3 Gold Package Hydraulic (Master Cylinders, Bias Bar etc) £360 £423.00
H4 Standard Pedal Box Hydraulic £100 £117.50
H5 Hydraulic M/cyl to Pedal Clevis Link £7 £8.23
H6 Cable Clutch Spacer and Nylon Insert £19 £22.33
H7 Master Cylinders Race (each) £38 £44.65
H8 Master Cylinders Road S.V.A .7, .75 & .625 (each) £42 £49.35
H9 Remote Reservoir, S.V.A (each) £22.00 £25.85
H10 Remote Double Reservoir, SVA £35 £41.13
H11 Bias Bar with tube (Adjustable) £30 £35.25
H12 Sierra Handbrake New No Modification £45 £52.88
H13 Sierra Short Handbrake £70 £82.25
H14 Push Fit M/Cyl Nipples £8 £9.40
H15 4 way £11 £12.46
H16 Brake Light Switch £9 £9.99
H17 3 way £8 £8.87
H18 Female & Male Fittings £1 £1.18
H19 Non Return Valve £8 £8.81
H20 Throttle Multi Fit Cable £12 £13.51
H21 Disc Brake Cable (Modified) £25 £29.38
H22 Drum Brake Cables x 2 £24 £28.20
H23 Sports Hand Brake Cover £31 £36.43
H24 Steering Column Fitting Bush £3 £3.53
H25 Gear Shift Gaitor £13 £15.28
H26 Gear Knob Leather £14 £16.45
H27 Gear Knob Aluminium £28 £32.90
H28 3/16 Copper Brake Pipe a Roll £7 £8.23
H29 Rear callipers a pair £242 £284.35
H30 Rear Callipers Sliders a pair £60 £70.50
H31 Willwood 4 Pots x 2, 257 x 12mm Powerlite Sierra Fitment £550 £646.25
H32 Powerlite Smart Pads Sierra Fitment £30 £35.25
H33 Overcentr Bonnt Clips x 4 £18 £21.15
Locost Fibre Glass and Panel Sets Locost (Ex) Inc VAT
K1 Rear Wings Pair (215mm I/D) £95 £111.63
K2 Rear Wings Pair Wide (280mm I/D) £120 £141.00
K3 Front Cycle Wings Pair (180mm I/D) £70 £82.25
K4 Front Cycle Wings Pair Wide (235mm I/D) £80 £94.00
K5 Scuttle Locost £110 £129.25
K6 Bonnet Locost £120 £141.00
K7 Rear Panel Locost £110 £129.25
K8 Nose cone Locost £110 £129.25
K9 Dash Board with Carbon Fibre top layer Locost £75 £88.13
K19 8 Piece Locost GRP (Standard Wings) £520 £611.00
K10 Inner panel Set with fine brush finish, Aluminium £185 £217.38
K11 Side Panel Set with fine brush finish, Aluminium (Road) £185 £217.38
K12 Side Panel Set with fine brush finish, Aluminium (Race) £145 £170.38
K13 Full Panel Set with fine brush finish, Aluminium £365 £428.88
K14 Parcel Shelf panels with fine brush finish, Stainless Steel £110 £129.25
K15 Inner panel Set with fine brush finish, Stainless Steel £275 £323.13
K16 Side Panel Set with fine brush finish, Stainless Steel (Road) £365 £428.88
K17 Side Panel Set with Mirror finish, Stainless Steel (Road) £455 £534.63
K18 Full Panel Set with fine brush finish, Stainless Steel £545 £640.38
K19 Parcel Shelf panels with fine brush finish, Stainless Steel £120 £141.00
K20 Boot Box Ali Locost 45 52.875
K21 Rear Parcel Shelf Ali Locost 55 64.625
K22 Rear Parcel Shelf Brushed and Mirror St/St 92 108.1
K23 Stone Gaurds Viento & Velocity Ali 28 32.9
K24 Stone Gaurds Viento & Velocity St/St Brushed & Mirror 47 55.225
Velocity Fibre Glass and Panel Sets Velocity (Ex) Inc VAT
KL1 Rear Wings Pair (215mm I/D) £100 £117.50
KL2 Rear Wings Pair Wide (280mm I/D) £120 £141.00
KL3 Front Cycle Wings Pair (180mm I/D) £70 £82.25
KL4 Front Cycle Wings Pair Wide (235mm I/D) £80 £94.00
KL5 Scuttle Velocity £120 £141.00
KL6 Bonnet Velocity £140 £164.50
KL7 Rear Panel Velocity £110 £129.25
KL8 Nose cone Velocity £120 £141.00
KL9 Dash Board with Carbon Fibre top layer Velocity £75 £88.13
KL10 8 Piece Velocity GRP (Wide Wings) £685 £804.88
KL11 Inner panel Set with fine brush finish, Aluminium £185 £217.38
KL12 Side Panel Set with fine brush finish, Aluminium (Road) £185 £217.38
KL13 Side Panel Set with fine brush finish, Aluminium (Race) £145 £170.38
KL14 Full Panel Set with fine brush finish, Aluminium £365 £428.88
KL15 Parcel Shelf panels with fine brush finish, Stainless Steel £110 £129.25
KL16 Inner panel Set with fine brush finish, Stainless Steel £275 £323.13
KL17 Side Panel Set with fine brush finish, Stainless Steel (Road) £365 £428.88
KL18 Side Panel Set with Mirror finish, Stainless Steel (Road) £455 £534.63
KL19 Full Panel Set with fine brush finish, Stainless Steel £545 £640.38
KL20 Parcel Shelf panels with fine brush finish, Stainless Steel £120 £141.00
KL21 Boot Box Ali Viento & Velocity 45 52.875
KL22 Rear Parcel Shelf Ali Viento & Velocity 55 64.625
KL23 Rear Parcel Shelf Brushed and Mirror St/St Viento & Velocity 92 108.1
KL24 Stone Gaurds Viento & Velocity Ali 28 32.9
KL25 Stone Gaurds Viento & Velocity St/St Brushed & Mirror 47 55.225
Clocks, Senders and Sensors
L1 Digi Dash Base Unit (BASIC) £546 £641.55
L2 Digi Dash Upgrade (Race/Track Day Lap Timer) £92 £108.10
L3 Digi Dash Upgrade (Mini-Log) £38 £44.65
L4 Digi Dash Ugrade (Additional Timer) £38 £44.65
L5 Digi Dash 2 Pro Datalogging System £1,002 £1,177.35
L6 White Face 80mm Clocks S.V.A (Volt, Oil pressure, Water temp, Fuel, Revs, Elec Speedo, Fuel Sender, Oil switch) £465 £546.38
L7 White Face 100mm Clocks S.V.A (Volt, Oil pressure, Water temp, Fuel, Revs, Elec Speedo, Fuel Sender, Oil switch) £550 £646.25
L8 100mm Electronic Tachometer, 0-8000 Rpm (black or white face) £120 £141.00
L9 80mm Electronic Tachometer, 0-8000 Rpm (black or white) £75 £88.13
L10 100mm Speedometer Electronic, 0-140 Mph (black or white) £190 £223.25
L11 80mm Speedometer Electronic, 0-140 Mph (black or white) £180 £211.50
L12 52mm Fuel Gauge to match lever arm fuel sender (black or white) £25 £29.38
L13 52mm Water Temp gauge 40-120 C (black or white) £25 £29.38
L14 52 mm Oil pressure gauge 0-90 PSI (black or white) £25 £29.38
L15 52 mm Voltmeter 8-16V (black or white) £25 £29.38
L16 Water Temp Sensor £9 £10.58
L17 Oil Pressure Sender £30.00 £35.25
L18 Fuel Sender top mounted 6 hole Smith type £23 £27.03
L19 Light Duty Inductive Speed Sensor £30 £35.25
L20 Magnets (2 Per Pack) £3 £2.94
L21 Thread Adapter (1/4" nptf) £4 £4.70
L22 Adapters for senders most threads available £4 £4.70
Electric’s, Windscreen & Hood
M1 Wiring Loom with fuse box (Velocity) £120 £141.00
M2 Wiring Loom with Fuse Box (Viento) £120.00 £141.00
M3 Front head lamps with integral side lights a pair 5 3/4" (Black finish) £130 £152.75
M4 Front head lamps with integral side lights a pair 5 3/4" (Chrome finish) £130 £152.75
M5 Front head lamps with integral side lights a pair 7" (Black finish) £155 £182.13
M6 Front head lamps with integral side lights a pair 7" (Chrome finish) £155 £182.13
M7 Mini style indicator s a pair £38 £44.65
M8 Stalk indicators a pair £18 £21.15
M9 Side repeater a pair £19 £22.33
M10 Rear light unit a pair (Reflector, indicator, brake, side) £36 £42.30
M11 Number Plate Light Black £24 £27.61
M12 Fog Light £25 £29.38
M13 Reverse Light £25 £29.38
M14 Carbon Look Plinths Double a Pair £70 £82.25
M15 Carbon Look Plinths Singles Each £14 £16.45
M16 Velcoity Light Set £255 £299.63
M17 Viento Light Set £285 £334.88
M18 10" Pacet Fans Push Or Pull £75 £88.13
M19 Windscreen with Surround £163 £191.53
M20 Windscreen support mild steel £30 £35.25
M21 Windscreen support Aluminium £50 £58.75
M22 Wiring Relay Pack (For Sierra Steering Column) £20 £23.50
M23 Velocity Hood with Side screens £685 £804.88
M24 Complete wiper Motor kit cut to size - ready to fit £220 £258.50
M25 Heater - 3 speed £260 £305.50
M26 Washer bottle, a twin jet & Tube & press button switch £40 £47.00
M27 Warning Light With Symbol £5 £5.88
M28 Side Mirrors £58 £68.15
Seats and Harnesses
N1 Cobra Signature Roadster Seat trimmed in Vinyl (with choice of colour) £203.00 £238.53
N2 Cobra Signature Roadster Seat Black Vinyl / Black Vinyl piping £203 £238.53
N3 Harness slots in head pad £35 £41.13
N4 Universal sub frame (each) £45 £52.88
N5 SVA 4 point harness (each) £45 £52.88
N6 Monaco's Choice of Black/Blue/Red Nylon Fabric / Black Patches (VIENTO) £145 £170.38
N7 Imola's-Blackrock all over-Suede Tech Patches (VIENTO) £277 £324.89
N6 GRP bucket seat - Standard £110 £129.25
Uprights, Steering, Propshafts & Cooling
O1 Escort MkII Quick Racks 2.9 Ratio £80.00 £94.00
O2 Escort MkII Quick Racks 2.4 Ratio £120.00 £141.00
O3 Escort MKII (LHD) £150.00 £176.25
O4 Rack Extension Velocity £16.00 £18.80
O5 Rack Extension Viento £16.00 £18.80
O6 V8 Radiator £270.00 £317.25
O7 Double Core Rad Velocity £118.00 £138.65
O8 Sierra Uprights New With Modification £145 £170.38
O9 Sierra Downlink New Viento £60 £70.50
O10 Sierra Downlink New Velocity £55 £64.63
O11 Goodridge Locost Braided Hose Set of 4 Live Axle Drum £40 £47.00
O12 Goodridge Vieno Braided Hose Set of 4 Drum £40 £47.00
O13 Goodridge Vieno Braided Hose Set of 4 Disc £40 £47.00
O14 Goodridge Velocity Braided Hose Set of 4 Drum £40 £47.00
O15 Goodridge Velocity Braided Hose Set of 4 Disc £40.00 £47.00
O16 Steering Rack Brackets Escort MKII £19.50 £22.91
O17 Prop Shaft Standard Type 9 to Sierra Diff £198.00 £232.65
O18 Prop Shaft Hi-Performance Type 9 to Sierra Diff £230.00 £270.25
O19 10" Steering Wheel £54.20 £63.69
O20 Steering Column Cover Ali £20.00 £23.50
O21 Donor Steering Column with Switches £100.00 £117.50
O22 Steering Boss to Fit Sierra £21.70 £25.50
Exhausts
P1 Exhausts V8 Full System £1,100.00 £1,292.50
P2 Exhausts Zetec Full System £520.00 £611.00
P3 Exhausts Pinto Full System £545.00 £640.38
P4 Exhausts Toyota 16V & 20V Full System £545.00 £640.38
P5 Exhausts X Flow Full System £520.00 £611.00
P6 Exhaust polishing Single £185.00 £217.38
P7 V8 Exaust Polishing £265.00 £311.38
P8 Exhaust Headers, Ztec, Toyota, Pinto, X Flow £364.00 £427.70
P9 Silencer £136.50 £160.39
Race Spec GRP
Q1 Nose Cone £95.00 £111.63
Q2 Front Wings (Pair) £46.00 £54.05
Q3 Rear Wings (Pair) Standard £74.00 £86.95
Q4 Rear Wings (Pair) Wide £95.00 £111.63
Q5 Rear Panel £95.00 £111.63
Q6 Locost Race Bonnet £100 £117.50
Q7 Locost Race Scuttle £92 £108.10
Q8 Locost Race 8 Piece Wide £536 £629.80
Q9 Velocity Race Nose Cone £110 £129.25
Q10 Velocity Race Bonnet £118 £138.65
Q11 Velocity Race Scuttle £110 £129.25
Q12 Velocity Race Back Panel £92 £108.10
Q13 Velocity Race 8 Piece Set £580 £681.50
Merchandise
R1 Flash Jacket Black with Logos (Ladies) S, M, L £73.00 £85.78
R2 Flash Jacket Black with Logos (Mens) S, M, L £73.00 £85.78
R3 Sweat Jacket Black with Logos (Ladies) S, M, L £38.50 £45.24
R4 Sweat Jacket Black with Logos (Mens) S, M, L £38.50 £45.24
R5 T Shirt Black with Logos (Ladies) S, M, L £23.56 £27.68
R6 T Shirt Black with Logos (Mens) S, M, L £23.65 £27.79
R7 Wooly Hat Black with Logo (One size) £8.50 £9.99
R8 Baseball Cap Black with Logo (One Size) £8.00 £9.40
R9 Long Sleeve T Shirt Dark Grey/Black with Logos S, M, L £18.50 £21.74
R10 Full Zip Sweat Shirt with Logos Black S, M, L £35.00 £41.13
R11 T Shirt Black with Logos (CHILDS) £13.00 £15.28
