Author: Subject: Sierra 4x4 rear hubs - part numbers
rickys2000
posted on 17/4/06 at 04:15 PM Reply With Quote
As the subject says...........Does anybody know the part number for the complete rear hub assembly less the disks and calipers.
Ford tell me they can't order the parts without a registration number.......
Ricky
Donners90
posted on 17/4/06 at 05:14 PM Reply With Quote
I'll look on E-CAT at work tomorrow and let you know.
James
dave1888
posted on 17/4/06 at 05:37 PM Reply With Quote
Do you mean the bearing carriers.
Donners90
posted on 18/4/06 at 10:20 AM Reply With Quote
Part nos
Assuming it has rear Discs then FINIS numbers are:-
5 - 6146626
6 - 6140418
7 - 6140417
8 - 6156880
9 - 6586309
10 - 6102937
11 - 6133688
I can't get the P/N for the stub shaft I'm affraid.
HTH
rickys2000
posted on 18/4/06 at 08:39 PM Reply With Quote
Perfect.................Thanks James
Ricky
St Peter
posted on 24/1/07 at 01:02 PM Reply With Quote
4x4 Sierra Hubs
Hi, I am building a wide bodied locost similar to Viento with a chassis and rear uprights produced years ago by Luego.
I now have a problem fitting the hub/bearing/caliper carriers to the upright.
has anybody done this before and can they tell me how? Do I need new uprights, or can any body supply drawings to fabricate or modify the ones I have? I intend to use 4x4 diff and Lobro joints for use with a Cosworth turbo lump and T5 Gbox.
Thanks in anticipation
St. Peter
simonk
posted on 24/1/07 at 01:41 PM Reply With Quote
Viento hubs
Hi St.Peter
My Viento rear hub carriers went together with the uprights no problem - what's not fitting together ?
Simon
St Peter
posted on 24/1/07 at 03:11 PM Reply With Quote
4x4 Sierra Hubs
Hi Simon,
My uprights were I think made for drum brakes, I am trying to fit solid disc with handbrake calipers.
The hubs didnt fit into the upright, however I have fixed that, but there is now problems with fixing the caliper mounting bracket to the upright and machining part of the upright away to give clearence for back of caliper ! This will mean I will probably have to add webs on the upright to retain strength. I will attach photo when available.
In the mean time I am going to resort to a CAD package to draw the whole thing out. Unless that is anybody has a drg of a Luego style IRS rear upright suitable for Lobro joints.
St. Peter
St Peter
posted on 24/1/07 at 10:26 PM Reply With Quote
Stub shaft part numbers
I have looked at my stub shafts and found the following pt nos
85GB-4K137 BC-L (LH Thread)
85GB-4365 BC-R (RH Thread)
St Peter
simonk
posted on 25/1/07 at 01:16 PM Reply With Quote
Uprights
If the backend is stock Viento geometry might it be an easier option to get Dean at New Luego to price you some disc uprights ? I'm not a fabricator so generally take the easy option, but against modding the drum uprights the relatively modest cost of disc uprights would be the choice for me.
Best of luck
Simon
