heyzee
posted on 29/4/06 at 04:27 PM |
engine lift
fitted my r1 engine in the cradle and fit it to the car,cut airfilter housing down a little and moved air intake hole.turned filter houseing round and
fit it to the engine..now i have over 35 mm of spare room on top end under the bonnet,what would be best to use as spacers to lift the engine and gain
more ground clearance with the sump..i was thinking of getting some bits of solid bar and haveing a 12.5mm hole drilled out line them up on the
chassis brackets and weld them to them,then weld the lower mounts in ..can anyone see a problem with this...
stevec
posted on 29/4/06 at 07:01 PM |
Beware of possible propshaft alignment probs by raising the engine more than a bit, I think MK think about that when they make the cradle.
zxrlocost
posted on 29/4/06 at 07:31 PM |
wouldnt bother leave it be
posted on 29/4/06 at 07:44 PM |
lower is better from a centre of mass point of view. Is it quite far below the bottom rails?
cossey
posted on 29/4/06 at 09:56 PM |
from one point of view raising it is a good idea as you can then lower the whole car and overall lower the centre of gravity as the sump clearance
normally determines chasis height but this isnt always possible.
heyzee
posted on 30/4/06 at 11:56 AM |
when the engine is sat in the cradle and the cradle is sat on the brackets the engine sits about 55 mm below the bottom of the chassis rails.its just
ive read on previous posts that some sit 50mm and some fit 25mm and i think one builder has even sat his level.would i be able to go over speed humps
if it pertrudes 55mm below???or is there a big risk of grounding out??and if i get the sump chopped how mutch do they take off????its a 2003 engine im
useing..
heyzee
posted on 1/5/06 at 08:49 AM |
how far down does everyone elses engine hang down under the chassis rails.and how far off the floor does the car sit????
posted on 1/5/06 at 09:32 AM |
my engine is 1" below the bottom of the car, and around 4" off the ground. Hence car is closer to 5" up.
zxrlocost
posted on 1/5/06 at 09:40 AM |
my r1 engine is low to the floor its a racing car really
if you mess have you thought about coolant pipes etc etc etc
my car goes over normal speed ramps ok
but I wouldnt bother with the twin ramps ie the two side by side
