Das
posted on 1/5/06 at 09:46 PM |
zetec to type 9 with xflow bellhousing
Hi , I'm replacing a lotus twin cam with a zetec , it has a type 9 gearbox with xflow type housing , I know I can use the raceline parts but
these are expensive , if I use an 1800 flywheel can anybody tell me what , clutch , pressure plate and starter motor I can use ?
Krismc
posted on 2/5/06 at 03:25 PM |
i used a pinto clutch, pinto lightend flywheel, FRS122 starter, type 9 box, with type 9 standard housing, straight onto zetec and all seems fine
