Author: Subject: veypor vr2
Paul (Notts)
posted on 3/5/06 at 05:09 PM Reply With Quote
veypor vr2
where is the best place to buy a veypor vr2 display system from ?
I know there was a group buy a few months ago but at the time I was concentrating on other areas of the car.
Thoes who fitted it any comments or pics..
Cheers Paul
Guinness
posted on 3/5/06 at 05:14 PM Reply With Quote
I have one, it's a very cool toy.
I'm using a Veypor VR2. 'Tis a good bit of kit, with several functions:-
Tacho, speedo, distance travelled, gear indicator, shift light and g meter.
They also regularly update the software adding new features. They have just added a virtual fuel gauge (with MPG, range etc) and a servicing timer which you can programme to come up on hours engine run or miles. Last update also added 4-5 different options on the display.
However it does not monitor:-
engine water temp, oil temp, oil pressure, volts, amps, etc, so you would need additional dials to cover them.
I always intended fitting the 3 gauge set from NFAuto once I'd passed the SVA.
It does however have some cool features though, data logging, 0-60 runs, staged 1/4 miles, 50-70 timer, 70-0 timer.
The V-Max feature on mine seems to be broken, either that or perhaps I picked up one of Darrens missing magnets, cause mine was showing 125 on Sunday.
HTH
Mike
k33ts
posted on 3/5/06 at 06:03 PM Reply With Quote
contact hotsotbeans he may be able to sort you out
tukcustoms.com
mackei23b
posted on 3/5/06 at 08:48 PM Reply With Quote
MK now selling the speedwell digital dash. looks good, you should have a look at it
Ian
