flak monkey
posted on 15/5/06 at 08:01 PM |
What flexis?
Probably been asked a load of times....
What brake flexi lines do i require for my GTS? Will a set to suit a cortina be long enough? I am running the same set up at the front as the original
cortina (ie a short solid pipe on the caliper, then the flexi).
I am planning on buying a goodridge set or a set from rally design so theres no sva hassles...
[Edited on 15/5/06 by flak monkey]
Sera
http://www.motosera.com
Deckman001
posted on 15/5/06 at 09:20 PM |
mac#1 also do sets, I have no idea how they compare to RD though on cost .
Jason
Danozeman
posted on 16/5/06 at 09:27 AM |
Mac1 maybe cheaper. The problem i find with RD is that if its a small light item then the postage is silly.
Eg a silicon hose from them for a tenner costs 8.50 to post.
Dan
rally design
posted on 16/5/06 at 05:07 PM |
Rally Design answer postage
Just to let everybody know that the default setting on our website is £8.50,the website is not clever enough to know weight/size/shape etc but we try
to be fair...if it's a metre length of silicon hose it is too long to go in the post,but if it's a small,light or inexpensive item,without
a stated method of despatch then we try to be fair and put it in the post at £3.00,if it's under 2 kilos and/or over £20.00 and relatively small
it goes in a Maildoc bag at £6.00 but there are times when it's cheap but bulky and we have to use the courier service at £8.50.
Hope this helps understanding our system.
