Author: Subject: Current draw of 'boot poppers'?
RazMan
posted on 24/5/06 at 02:46 PM Reply With Quote
I'm going to fit a couple of these as remote door lock actuators in my middy (saves mechanical linkages etc) and wondered if anyone knows what current they draw to get a reliable action. I want to have the doors powered by a separate (small) battery which will be independent from the main battery and need to know how big it need to be.
Raz
k33ts
posted on 24/5/06 at 05:20 PM Reply With Quote
there quite high dont know exact figures but i know they pop a 10amp fuse
tukcustoms.com
RazMan
posted on 24/5/06 at 09:18 PM Reply With Quote
10A EACH ?? !!
Looks like I might have to rethink
Raz
ady8077
posted on 24/5/06 at 09:54 PM Reply With Quote
Hi
Its probably the surge that blows a fuse, why do you want them off a secondary battery?
Adrian
RazMan
posted on 24/5/06 at 10:03 PM Reply With Quote
I intend to use the battery cutoff switch when parked but if I close the doors with the power off I won't be able to get in the car.
I thought a secondary battery (the type used as backups in alarms) could be linked to the main one using a diode to stop it draining when the main one is switched off. That way I can always get in the car .............. which is nice
If they take 10A I might have to wire them direct to the main battery instead. Only drawback will be the flat battery scenario
Raz
k33ts
posted on 24/5/06 at 10:27 PM Reply With Quote
i take it your havin no door handles or locks and that when you say parked you mean left in the garage as the solenoid wont drain it.
the best way to get over the flat battery is to hide a socket maybe a cigarette type(hella do some nice waterproof ones) under or somewhere accesable but no visable.
itll be handy for say trickle charging when your not using motor and especially so if you get a flat battery.
hella blugs and sockets
http://www.4x4cb.com/public/shop_preview/products2.cfm?CatID=518
[Edited on 24/5/06 by k33ts]
tukcustoms.com
greggors84
posted on 24/5/06 at 11:00 PM Reply With Quote
You could run them off the same battery, and have the battery cut off switch isolating the rest of the electrics. Still would have a problem with the flat battery scenario though if you left the lights on etc.
Chris
The Magnificent 7!
chockymonster
posted on 24/5/06 at 11:09 PM Reply With Quote
A friend had a similar setup, to get around the flat battery problem he had a a pp9 battery connector connected directly to the driver's door and hidden securely. A pp9 had enough juice to fire the door popper to let him in to the car.
RazMan
posted on 25/5/06 at 06:55 AM Reply With Quote
Aha so it looks as though the 10A figure was a little ott to say the least - if a pp9 can operate a solenoid it can only be a few mA.
I think I will do as suggested and have a 12V socket discretely hidden somewhere for emergencies (and trickle charging) and have the solenoids bypassing the cutoff switch.
Thanks guys
[Edited on 25-5-06 by RazMan]
Raz
ady8077
posted on 25/5/06 at 10:02 PM Reply With Quote
Is it ok to have auto doors for SVA?
Adrian
stevebubs
posted on 25/5/06 at 10:45 PM Reply With Quote
TVR Chimaeras don't had door handles just buttons...
Crazy Jay
posted on 25/5/06 at 11:59 PM Reply With Quote
They wont pass mot normally. I know a guy who had to have a spare set of doors for his mot coz he had de-handled his car
RazMan
posted on 26/5/06 at 07:05 AM Reply With Quote
Hmm ... interesting - so how do Chimaeras pass mot I wonder?
[Edited on 26-5-06 by RazMan]
Raz
ady8077
posted on 26/5/06 at 04:20 PM Reply With Quote
Hi
I sva'd my stylus with no outer door handles, just internal ones, but i didn't have locks. SVA man never mentioned it
My stylus and TVR's are soft tops though, maybe that helps?
Adrian
