Author: Subject: air box
Robert Ryan
posted on 27/5/06 at 10:05 PM Reply With Quote
air box
I am fitting a sock filter to me R1. at present it has a flat solid plate. After cutting the 4 holes, do I need to us any parts from the old R1 filter.also do I remove the rubber trumpets.
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
Building: MNR Vortx r1(sva pass 07 plate yumyum)
posted on 27/5/06 at 10:44 PM Reply With Quote
Hi
I have fitted mnr filter to mine cut holes in base plate and sandwiched it between top ducts by removing the 8 screws and placing base in and then retighten all screws i didn,t use trumpets and don,t recall seeing any on marcs vortx either
Hope this helps
Winston Todge
posted on 28/5/06 at 07:47 AM Reply With Quote
I am endeavouring to keep the standard R1 airbox and rubber trumpets and am having a custom built exhaust manifold 4-2-1 for my VortX.
The reason is that if you spend so much money and time on your car it would be little less satisfying to end up stangling it with a less efficient intake and exhaust system...
The very least that should be done is radiusing of the carb inlets where the rubber trumpets used to sit. But if you can retain the trumpets, it dramatically effects the bikes ability to flow air at lower revs. This is why I'm trying so hard to slightly mod my airbox and bonnet (bulge) to fit the standard airbox in. (If it's good enough for the RGB guys it's good enough for me!) (See http://www.locostbuilders.co.uk/viewthread.php?tid=39230)
As for the exhaust I am having an equal length 4-2-1 system custom built for it. It has been proven that a good 4-2-1 can boost low to mid range torque and provide the best overall driveability for a road car.
Chris.
posted on 28/5/06 at 08:20 AM Reply With Quote
Chris.
Could you show us all the evidence you have to support this claim as many 4-2-1 systems out there are not equal length...
richijenkin
posted on 28/5/06 at 08:57 AM Reply With Quote
Im using a tts sock filter and using the trumpets off the original airbox
[Edited on 28/5/06 by richijenkin]
Bryan Sears
posted on 28/5/06 at 10:34 AM Reply With Quote
RichieC
posted on 28/5/06 at 10:38 AM Reply With Quote
Im sure it will aid in not sucking in as much hot air (providing it is fed as such) but it wont allow proper CAI as the box needs to be sealed. That will still suck under bonnet air.
There seems to be great mystery about how to succesfully fit the stock airbox. Ive heard different ways of doing it, but I cant see an easy way under the MNR bonnet.
Rgds
Rich
Meant to ask Bryan, could you get it to seal onto the underside of the bonnet? If so, feeding it with a scoop would constitute a proper cold air induction system.
[Edited on 28/5/06 by RichieC]
RichieC
posted on 28/5/06 at 10:39 AM Reply With Quote
Meant to ask, scoey m etc - what size holes did you drill through the air filter back plate?
Rgds
Rich
Bryan Sears
posted on 28/5/06 at 10:47 AM Reply With Quote
RichieC
posted on 28/5/06 at 10:49 AM Reply With Quote
Yep, that would work.
Are you feeding it with fresh air from the front of the car rather than it sucking under bonnet air in?
Either way its going to improve noise for the SVA and providing the air entering it is cool enough, it will be better all round.
Rgds
Rich
Paul G
posted on 28/5/06 at 10:55 AM Reply With Quote
Dont forget the cocktail sticks!
RichieC
posted on 28/5/06 at 10:57 AM Reply With Quote
Is that to block up the air holes?
Heard various opinions about that, whats the thought behid it?
Rgds
Rich
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
posted on 28/5/06 at 05:12 PM Reply With Quote
Hi rich
Can't remember off hand but 65mm rings a bell all four filed by hand easy task
smart51
posted on 28/5/06 at 05:22 PM Reply With Quote
The cut off air box will have a smaller volume than the standard box. I believe that volume is important in tuned air systems. I don't know, though, what effect reducing the volume will have.
I have a foam filter without trumpets. I have an MNR exhaust. far from strangling the engine, I've had to up the fuelling to get it right. It would appear to be flowing more air than before.
RichieC
posted on 28/5/06 at 06:47 PM Reply With Quote
Originally posted by scoey m
Hi rich
Thanks mate, bigger than I thought but i can pop the trumpets off easily and see for sure.
Thanks and Rgds
Rich
Winston Todge
posted on 28/5/06 at 10:07 PM Reply With Quote
My opinion is based on professional's opinions that I have sourced in the last few days...
I'm sorry if that offended anyone. But I have made the choice to take the opinion of these people as reliable. I am not in the position to start posting dyno print outs.
I am not saying that Marc's mainfolds are badly designed as on the same page he advertises the 325 quid unequal length manifolds he advertises a 600 quid 'equal' length race 4-2-1 manifold. It all depends on budget...
Don't take this as an arsey response. It's not meant that way.
Chris.
