ned
posted on 12/6/06 at 02:35 PM |
sealing tapered thread
having a spot of bother with my oil pressure sender thread. Its a 1/4"npt thread into the back of an ally oil pump housing on the xe. first of
all it leaked a lot and we managed to sort it with some ptfe tape but i'm not convinced its doing a very good job as i still get a little puddle
of oil under the car from running the engine up.
Is there some threadlock type stuff that will seal it up and that is ok with oil? Its very difficult to get to the thread to clean it up sufficiently
really.
Ned.
beware, I've got yellow skin
mike smith1
posted on 12/6/06 at 02:47 PM |
At work we install oil pipework and we use locktite 572 dont know how it performs on alloy. But seems to do the trick on most things
Mike
Megatron-UK
posted on 12/6/06 at 02:49 PM |
Ned, my escort does this when hot - we can't seem to stop it either. Are you referring to the section on the oil filter housing that is
connected to an oil cooler when installed in the Astra/Cavalier? My next attempts will probably involve taking out the bungs and refitting new oil
lines and an oil cooler.
posted on 12/6/06 at 02:52 PM |
has it bottomed out i.e. you cannot do it up any tighter?
or if there is a step on the nut, maybe a copper washer or o-ring?
I had small oil leak on my v8 - turned out the brass fitting for the oil pressure sender & adapeter were not tight enough - did up both the
adpapter and sender end and sorted.
something else to try is to use some eletrical solder - softer than plumbers - and put that onto the thread? just one turn's worth on the
adapter.
or araldite?
ned
posted on 12/6/06 at 03:04 PM |
its a tapered thread so no flat for any sort of washer. its the rear facing thread on the back of the oil filter housing megatron, poinmts towards the
starter. i've got a remote sender on the end of a braided line isolated on the chassis. I'll see if i can find a pic..
Ned.
bottom right of engine on this pic:
http://www.locostbuilders.co.uk/upload/IMG_1707b.jpg
access is a bit tricky, bottom rightish of photo behind the silicone hose t-piece:
http://www.locostbuilders.co.uk/upload/IMG_1975b.jpg
[Edited on 12/6/06 by ned]
Megatron-UK
posted on 12/6/06 at 03:13 PM |
Ah, gotcha... I think on my XE the sender threads do stick out a way and we did put a fair amount of ptfe tape on too!
Syd Bridge
posted on 12/6/06 at 04:01 PM |
The Loctite pipe seal that doesn't harden is the best a man can get.
Syd.
RazMan
posted on 12/6/06 at 09:21 PM |
Loctite Threadseal 577 is the best stuff to use. Threadlocker is more for your average nut & bolt problem.
[Edited on 12-6-06 by RazMan]
Raz
Stu16v
posted on 12/6/06 at 09:39 PM |
Ned, p'raps I'm missing the point, but IIRC the thread at the back of the oil pump is 14mm...
NS Dev
posted on 12/6/06 at 09:40 PM |
tis indeed Stu, very similar in terms of size to 1/4 npt, but it most certainly aint!
ned
posted on 13/6/06 at 06:55 AM |
well i had a 14mm->1/8npt adapter but it didn't fit the hole and the 1/4npt one did ?!
Ned.
guess i'll dig it out and try it again but i could never get the thread started as figured it was the wrong thread when i found the 1/4 was
nearly the same size and fitted.
[Edited on 13/6/06 by ned]
