Author: Subject: turbocharging a BEC???
peterriley2
posted on 13/6/06 at 09:09 PM Reply With Quote
I was wondering about turbocharging an r1 bec, and i was thinking about taking a charger out of a 1.0td car, such as diahatsu charade. would this be feasable, and if so would it be relatively straightforward. i know that turbos run off exhaust gasses, and would that mean redirecting from the manifold, as i want to keep the exhaust tubes protuding from the car as mormal, as i really like the look they give all in a line coming out the side. any ideas from blower specialists would be welcome
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
MikeR
posted on 13/6/06 at 09:16 PM Reply With Quote
Well if you insist on keeping the pipes then you'd have to put the turbo after they join into one pipe, which means sticking it down the side of the car, you'd then have to run a pipe back to the inlet side .......... this would give you HUGE amounts of lag, actually, no i'm wrong, i mean hHh uUu gGg eEe amounts of lag.
Oh, and you'll need an oil feed to the turbo as well, if you're doing it properly an intercooler on the pipe between the turbo and the inlet manifold.......
Also, a 1litre diesel engine turbo will be designed for that application, if you've got a 1 litre petrol running at twice / three times the RPM, you'll get that much more exhaust gasses, will it still work? will it still be efficient?
(i'm no expert, before someone points out where i'm wrong - but if you want to turbo, you want to get a turbo matched to the job you're doing and a custom exhaust and inlet + associated bits)
omega0684
posted on 13/6/06 at 09:24 PM Reply With Quote
urgh NO TURBOCHARGING, go with a supercharger less complicated and NO LAG!
MikeR
posted on 13/6/06 at 09:25 PM Reply With Quote
You only get (bad) lag if you've got a compromised setup. This conversation is currently being had on the sevens list.
The description of the well setup turbo car is like driving a nasp with a peaky cam.
Simon
posted on 13/6/06 at 09:29 PM Reply With Quote
This may help
http://www.holeshotracing.co.uk/tuning/turbo_bike_r1.asp
Simon
ChrisGamlin
posted on 13/6/06 at 09:35 PM Reply With Quote
Ive been in a friend's busa turbo and there's certainly no lag if you keep the boost sensible. His is currently running about 250bhp and its awesome, just feels like a big capacity normally aspirated engine with gobfuls of power everywhere.
Its not a cheap thing to do though, to do it even half properly you're looking at a £3-4k investment.
tigris
posted on 13/6/06 at 11:42 PM Reply With Quote
turbo
size your turbo based upon a normal car 2l (you are revving about twice as much) . I have been researching this for some time. A wrx td04l is about right, maybe something a little smaller for an 02-03 motor.
Nevermind the naysayers, you might experience some lag below 5k or so, but if you are driving an r1 BEC below that rev then give the thing to your grandma.
Mount the turbo outside of the car and throw a big filter on front, sounds pretty sweet.
alister667
posted on 14/6/06 at 03:53 AM Reply With Quote
We had a good discussion about this http://www.locostbuilders.co.uk/viewthread.php?tid=22090
and for a bike engine Garage19 recommended an early Fiat Uno or Diahatsu Charade turdo.
In the end that car we were hoping to modify got sold so we never got a chance to impliment the plan, but it might make a project over a winter some time for my own car.
Good Luck
Ali
http://members.lycos.co.uk/alister667/
peterriley2
posted on 14/6/06 at 10:09 AM Reply With Quote
cheers for those replies, it looks like i can either have a turbo, or a nice looking exhaust, so i was thinking about supercharging. what cars have superchargers on them, that i could possibly salvage from a scrapyard??i cannot think of any apart from extremely high performance cars, which certainly wont be locost, cheers
Joel
Gav
posted on 14/6/06 at 10:34 AM Reply With Quote
You would then need to extend the crank and add a pully to drive the supercharger iirc.
G.Man
posted on 14/6/06 at 01:21 PM Reply With Quote
TTS do a busa supercharger IIRC
http://www.tts-performance.com/busasupercharged.php
Yup
Google is your friend...
Opinions are like backsides..
kb58
posted on 14/6/06 at 05:39 PM Reply With Quote
Yeah, but $8000...
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 14/6/06 at 06:15 PM Reply With Quote
i did some compressor maps a while back and came up with a gt28-60 as a decent balance itll be boosting by 5krpm and be giving full boost by 6krpm. should end up with around 250-300bhp without running the charger into the inefficient speeds.
i seriously considered one but with the boost dropping off after 8.5k to give mid range torque without giving uncontrollable peak power.
MikeR
posted on 14/6/06 at 06:23 PM Reply With Quote
mini's (BMW) have them along with Jags
G.Man
posted on 14/6/06 at 08:49 PM Reply With Quote
Originally posted by kb58
Yeah, but $8000...
Only if they fit it, its about $5000 if you do it yourself I believe..
dilley
posted on 14/6/06 at 09:13 PM Reply With Quote
Im currently turboing my blackbird, dont even think about just bolting on a turbo to a stock engine, youll need about 5-6 k min, this will give you about 320bhp at wheels on a modified mitsubishi turbo, holeshot are doing mine at the mo.
kb58
posted on 15/6/06 at 01:52 AM Reply With Quote
I just realized that supercharger from TTS is probably a centrifugal type. In other words, a turbo driven by a belt. If so I don't see the advantage of it over a traditional exhaust-driven turbo. Either way, *if* it's not positive displacement, it won't help low-end rpm.
[Edited on 6/15/06 by kb58]
dilley
posted on 15/6/06 at 06:57 AM Reply With Quote
The only time you will get turbo lag is when you first pull away, once your on the move and banging through the box there will be no lag.
You need lag in first to catch grip.
