Author: Subject: alternator problem?
tractorboy
posted on 23/6/06 at 09:05 AM Reply With Quote
alternator problem?
i was driving at night on saturday and noticed that the alternator warning light was permanantly lit all be it dimly . i have noticed it flicker befor especially when accelerating. the battery is new but dont know where to look or what to test first . thanks for any help in advance .cheers scott
posted on 23/6/06 at 09:54 AM Reply With Quote
Have got a Bright 6 module? Mine does that - everything still functions OK so I no longer worry about it.
I might still put a hidden bulb in the circuit to stop it, though.
tractorboy
posted on 24/6/06 at 10:17 PM Reply With Quote
no i haven't got a module fitted .im just using tiger loom and standard set up( sierra style stalk and tiger switch gear) may have to resort to a standard employed on some of my old bangers ive had , 1 put up with it or 2 take the bulb out ! cheers scott
posted on 25/6/06 at 08:13 AM Reply With Quote
Could be the diode pack in the alternator breaking down ?
dave r
posted on 25/6/06 at 08:38 AM Reply With Quote
without the bulb it wont charge at all.
Dusty
posted on 28/6/06 at 10:58 PM Reply With Quote
Could well be the voltage regulator, particularly if during the day it seems to be hardly lit at tickover but gets brighter at high revs.
John Bonnett
posted on 29/6/06 at 05:31 PM Reply With Quote
It may be an alternator problem but first it might be worth checking the earth connection for your warning light. I believe one side of the warning light goes to the small connector on the alternator and the other direct to earth. This must be a good connection. I'm sure you have checked the fanbelt tension!!
John
tractorboy
posted on 1/7/06 at 07:15 AM Reply With Quote
thanks guys i will check all possible causes. cheers scott
