Author: Subject: Tach feed from coils??
chrisf
posted on 25/6/06 at 05:36 PM Reply With Quote
Hi All:
While I have the car torn to bits sorting other issues, I really need to solve my tacho problem. Right now, it only reads half the RPM. These are stock '98 'blade clocks on a stock '98 'blade engine. The engine wiring loom was modified by Westfield. and it looks like they pulled the tachometer feed from the ECU.
Now I cannot imagine why the ECY would spit out half the RPMs to the gauges, but it seems it does. My understanding is that it is possible to pull the RPMs from the negative side of the coils. How do I do this? Ans is this a better solution than feeding the tacho from the ECU?
How does the 'Blade ECU get its RPM info?
--Thanks, Chris
ruskino80
posted on 25/6/06 at 06:21 PM Reply With Quote
not sure about hoda but a recent fzr600 i rebuilt had the tacho feed (1 wire)teed into one of the coil (of the two)feeds-but traced back this also went to the cdi unit-connected up and it worked fine and that was with 94 clocks 92 loom and 90 cdi!
Ferrino
posted on 25/6/06 at 06:35 PM Reply With Quote
AIUI, if you take the RPM feed from a wasted spark coil you will get 2 'pulses' for every engine revolution, so I doubt this would work on a bike clock (ie. don't they expect one pulse for every rev?).
Bob C
posted on 25/6/06 at 10:35 PM Reply With Quote
Signal from a coil lead on a wasted spark system has 1 pulse per rev. Normal coil (on a distributor) gives 2 pulses per rev on a 4pot engine. When I worked on a ZX9R carbed engine, the ECU tacho output was 2 pulses per rev. On my homemade dash, I've so far assumed that the ECU output is 2 pulses per rev but I'm not sure yet if this is right or not (I'll have to see what the rev limiter and gear display say when I have some road to play with). I'd be a bit worried about feeding coil voltages into a tacho that's expecting a clean logic signal from an ECU - even the LT side of ignition coils see over 300V spikes every spark.
cheers
Bob
PS - in summary - your tacho might read 1/2 revs if it's wired to a coil instead of the ECU tacho signal - it would see 1 pulse per rev instead of 2
[Edited on 25/6/06 by Bob C]
chrisf
posted on 26/6/06 at 02:40 AM Reply With Quote
I found it!
Thanks for all the replies. Looks like BobC hit the nail on the head:
Frustrating Westfield would do that, especially since none of their diagrams show this!
