Author: Subject: Wishbones at funny angles?
tegwin
posted on 29/6/06 at 01:35 PM Reply With Quote
Do the front wishbones of a car have to be setup at 90 degrees to the direction of travel?
Or can they be setup like this: ?
(The angle is slightly exadurated!)
[Edited on 29/6/06 by tegwin]
[Edited on 29/6/06 by tegwin] Rescued attachment Not right.JPG
eddymcclements
posted on 29/6/06 at 02:33 PM Reply With Quote
They are like that on some of the GT40 replicas.
You can just about see it in this photo if the link has worked.
Eddy
nitram38
posted on 29/6/06 at 02:37 PM Reply With Quote
I wouldn't recommend it on front wheels unless the mounts are parallel to the wheel otherwise you will get tow-in/out effects.
Some racecars have the rears set so that as they load up, they actually steer into corners.
posted on 29/6/06 at 06:35 PM Reply With Quote
you can get away with it better on stiffish springs.
