Author: Subject: indicator and lighting circuit problem
Fishface
posted on 30/6/06 at 12:36 PM Reply With Quote
Can anyone help
My indicators on the lft side dont work, however they do when the hazard is turn on and the right side also works on its own. In additon when i turn the lights on all the lights on the switches for the hazards etc also all turn on?????
cct7kitcars
posted on 30/6/06 at 12:48 PM Reply With Quote
what wiring loom are you using
graememk
posted on 30/6/06 at 12:53 PM Reply With Quote
mine are better than that, i turn on my hazzards and my fuel pump goes on off on off lol
posted on 30/6/06 at 03:33 PM Reply With Quote
Recheck your wiring... are you using standard Sierra Indicators/Hazard Switch?
This is the most complex part of the build when building your loom from scratch which we (read as 'I' did
You're welcome to look at our website (if you like) and try to follow the Hazard/Indicator Wiring... it is pretty simple if you follow it logically.
The drawing is in Stuff/Help then click on the picture and it will enlarge.
HTH - Steve
John Bonnett
posted on 1/7/06 at 05:28 PM Reply With Quote
Hi, It is a good idea to check your earth. Peculiar things happen when there is a bad earth which can cause other lights to glow dimly or rear lights to go out when the brake lights come on. etc etc
Hope this helps
John
paulf
posted on 1/7/06 at 09:12 PM Reply With Quote
I had a very similiar problem when I got the earth and supply wires switched on one of my front indicators, I have them on bullet connectors to allow me to remove the nosecone, but somehow ended up with them in series between both indicator supplies and had the same symptoms.
Paul
Hope this helps
John
hearnia
posted on 3/7/06 at 08:44 PM Reply With Quote
Definately check your earthing arrangements. An easy test is to connect a wire direct from the negative side of your battery onto the negative side of the bulb holders and see if you have any joy.
A bad earth causes some funny problems!
Never compromise on a good earth!
