Author: Subject: electrics
graememk
posted on 7/7/06 at 09:44 PM Reply With Quote
electrics
well you might already know i bought the car part built, and i'm having a few probs with the wiring, mainly i have a loom but its been grafted onto the nissan loom after etc etc etc and i'm thinking about leaving the cable runs in and starting a fresh with one of these but it seems a lot of £££ is there a cheaper one, dont really have time to locost it fully
here
[Edited on 7/7/06 by graememk]
caber
posted on 7/7/06 at 09:49 PM Reply With Quote
IIRC the vicky Green loom complete costs about £85! better to do it all again rather than end up scratching yout head over someone elses bodged wiring!
Caber
graememk
posted on 7/7/06 at 09:51 PM Reply With Quote
all the wires are there, its the fuses and relays that are giving me the trouble
MikeR
posted on 8/7/06 at 09:04 AM Reply With Quote
i'd got with premier wiring loom - i've got one and so have a few others. mine isn't installed yet but it looks excellent.
posted on 8/7/06 at 09:07 AM Reply With Quote
Worth paying the extra for the premier loom !
irvined
posted on 12/7/06 at 11:27 AM Reply With Quote
Premier loom is tip top,
http://irvined.blogspot.com
posted on 12/7/06 at 12:53 PM Reply With Quote
I wired mine using a cut up Sierra loom from the donor and found wiring it easier than I thought it was going to be, put your equipment where you want it and wire it back to your fusebox then from the fusebox to the switches. Check your circuits work then put your relays in after in the circuits that need them. I used 8 way fuseboxes from the local shop for about £4 each and the relays from the donor.
k33ts
posted on 12/7/06 at 09:51 PM Reply With Quote
if your stuck bring it to northampton one saturday and ill sort it for you locost rates of course
tukcustoms.com
