Ferrino
posted on 12/7/06 at 09:24 AM |
Digidash Alarm Settings
I have an R1 engine and a Mychron 3 'digidash' (not the ETB one) and have some alarm LEDs to configure. I was wondering what a sensible
PSI value to to set the oil pressure warning light at?
I don't think I have the ability to incorporate RPM into the pressure alarm function, so I guess I will have to have the alarm LED illuminating
when the car is at hot idle (ie. when you get worryingly low oil pressures that are normal)?
Also, how about water & oil temps?
Thanks.
ChrisGamlin
posted on 12/7/06 at 06:08 PM |
If you cant set an X psi @ Y RPM, then I would personally set it at about 20-25psi. This will mean it will always come on at hot idle, but Id rather
it do that but know about a real pressure problem with reasonable warning than wait for it to drop to 8-9psi which is what it would need to be at to
avoid a hot idle alarm.
Chris
Ferrino
posted on 13/7/06 at 02:25 PM |
Cheers Chris - will go with that suggestion.
How about oil temp?
