Author: Subject: Who's Build Theirs With 1300 X Flow???
Michael
posted on 9/8/06 at 09:45 PM Reply With Quote
Just wondered how and where everyones put the essential items in their bonnet areas, like coil etc.
So if you have any pictures on your Photo Archive, jsut say I!
Thanks.
Surrey Dave
posted on 9/8/06 at 10:09 PM Reply With Quote
Fozzie
wicket
posted on 9/8/06 at 10:14 PM Reply With Quote
Mine's a 1600X-flow, but esstential items are much the same. There is a set of pictures in the Cooling folder in my photo archive which shows where the coil, header tank etc are located. If you need any more pics give me a shout
k33ts
posted on 9/8/06 at 10:21 PM Reply With Quote
1660 xflow under catch tanks
tukcustoms.com
Fozzie
posted on 9/8/06 at 10:33 PM Reply With Quote
Originally posted by Surrey Dave
Fozzie
You called oh wise one?
Yes Michael, I have a 1300 xflow in the fozzmobile.....
I do believe there are some pics in my photo archive.....mostly pre twin 40's though.....but should give a fair idea.....
Fozzie
Just had a look in my archive, and there have been a few minor changes since those pics were taken 2 years ago
I will endeavour to take some more very soon
[Edited on 9/8/06 by Fozzie]
posted on 10/8/06 at 08:51 AM Reply With Quote
I have 1300, not through choice
Location of coil is limited by the length of the leads to & from the distributor.
It is also helpful to fit it where is can get cold air flowing onto it, so not behind the radiator or on the exhasut manifold.
I welded a bracket to the top chassis rail, driver's side and bolted mine there, see below. You should also be able to see a Maplins ignition amp. (small black box with red LED)
