bob
| posted on 13/8/06 at 10:06 AM |
Zetec starter motor
Zetec series 1 silver top 1800 with type 9 box.
Which starter motor ?
Looking around the interweb the 1800 cvh or 2 litre DOHC from a sierra has been quoted a few times, part numbers i have are LRS 707 And LRS 543.
Can anyone tell me which one ?
many thanks
[Edited on 13/8/06 by bob]
Markp
| posted on 13/8/06 at 10:07 AM |
lrs 543 works for me
bob
| posted on 13/8/06 at 10:12 AM |
Thanks Mark
I have just worked out the LRS 543 has a smaller body, did you have to shave a bit off the sump to fit this starter ?
Danozeman
| posted on 13/8/06 at 11:18 AM |
IV got a 1.8 cvh on mine. Bolted straight on with an escort sump.
Dan
Chris.B
| posted on 13/8/06 at 12:07 PM |
Both LRS 707 and 543 physically fit. Key differences are:
543 has a shorter stubbier body 707 is a longer slimmer body.
543 has a longer throw of the starter gear on the spline.
I've got pictures of both somewhere & will dig them out. I had a 453 which & the throw was too long & consequently the flywheel ate
the starter cog. For me the 707 with a shorter throw was correct.
bob
| posted on 13/8/06 at 02:29 PM |
Thanks chris
I managed to get some more info and it looks like the 707 will do for me.
| posted on 13/8/06 at 03:22 PM |
Got mine off natehall from a 1.8 CVH Sierra. Winds the motor over good! Its tight but no mods to the sump needed.
[Edited on 13/8/06 by coozer]
Markp
| posted on 13/8/06 at 05:05 PM |
thats strange, the 707 was too short to get to the flywheel for me, what flywheel / clutch do you have
ATB Mark
bob
| posted on 13/8/06 at 05:20 PM |
Hello mark
I'm going to use the 1800 flywheel that came with the engine with an early 220mm escort/mondeo clutch kit along with the cct 133 release
bearing.
I'm was hopng this will be the same as everyone else,will have to wait and see who reports back
Markp
| posted on 13/8/06 at 05:23 PM |
I've used the tiger lightened flywheel, I've never compared the two so the 707 may be the one you need
Atb
Mark
stevebubs
| posted on 13/8/06 at 05:53 PM |
quote: Originally posted by bob
Hello mark
bearing.
I've a Sierra 1.8 CVH starter working perfectly on a Dunnell lightened 1.8 flywheel
| posted on 13/8/06 at 06:10 PM |
Hello mark
bearing.
Thats exactly what I have with the above picture of the starter. It all goes togeher ok and turns the motor over. Havent started it yet as I dont have
car to put it in!!
bob
| posted on 13/8/06 at 06:14 PM |
Cheers for that cooze
Thankyou everyone for the replies
Werner Van Loock
| posted on 13/8/06 at 07:35 PM |
I found the follwing website when I was searching for the LRS707
At the right there's a cross reference table with all starters that were used for the same engine (2.0DOHC)
You can also order a new OEM starter motor that is the same.
Maybe usefull to someone.
http://www.clubstylus.be
givemethebighammer
| posted on 13/8/06 at 07:44 PM |
Bob,
I have used the
Remy-Delco unit DRS 3468 (Sierra 1.8 CVH, 1988), this is the same as a Lucas LRS 707
works fine with my 1.8 Escort flywheel on my 2.0L zetec.
bob
| posted on 13/8/06 at 08:01 PM |
Great stuff as i have a 2nd hand 1800 cvh starter staring at me on the work bench and it only cost a fiver
