Author: Subject: Pinto Starter Motors
flak monkey
posted on 15/8/06 at 11:28 AM Reply With Quote
Has anyone got a bosch part number for a pinto starter motor to suit a 2 litre pinto with a T9 box? I have got a starter motor but its in bits, and I am not sure if it has come from an automatic engine or a manual and would like a basis for comparison.
I assume that all starter motors for T9 transmission 2 litre pinto sierras are the same? If so I might be able to get one from a scrappy.
Sera
http://www.motosera.com
DaveFJ
posted on 15/8/06 at 11:50 AM Reply With Quote
My starter is off a 2.0 Pinto inj ('97)
will have a look tonight to see what part numbers are on it.....
EDIT:. Off Manual Sierra with Type9 Gearbox
[Edited on 15/8/06 by DaveFJ]
Dave
mookaloid
posted on 15/8/06 at 11:54 AM Reply With Quote
The starters for manual and automatic are different handed - the manual fits on the passenger side and the auto on the drivers side
With the above info it should be obvious which one you have.
Mark
ADD
posted on 15/8/06 at 12:09 PM Reply With Quote
I will check tonight, but I may have a pinto starter knocking around you can have for nowt. It came offf the engine that was attached to your gearbox.
Hows the build going?
Adam
flak monkey
posted on 15/8/06 at 03:31 PM Reply With Quote
Cheers Adam.
Let me know if you find it.
Thanks for all the other info gents
Sera
posted on 15/8/06 at 09:39 PM Reply With Quote
i've got one spare off my 1.6 pinto donor. Its a QH part with a paper sticker on it that cant be read.
Is it the same as a 2.0L? Sure some one will tell me. Rescued attachment Pinto starter small.JPG
James
posted on 16/8/06 at 10:09 AM Reply With Quote
Looks identical to my 2.0 Pinto one if that's any use?
James
ADD
posted on 16/8/06 at 06:24 PM Reply With Quote
Just found the starter, if you want it U2U me.
Adam
