Ferrino
posted on 21/8/06 at 11:02 AM |
Damaged Coil? Diagnosis Required!
Was out testing my Translogic flatshift system last night and managed to hit a false-neutral. Slotted it back into gear and noticed power was way down
and thought the worst - however, it sounded like it was just misfiring (maybe running on 1-2 cylinders) and I nursed it home at 4,000 RPM (sounded
terrible).
Back in the garage, I noticed that exhaust pipes 2 & 3 were a lot cooler than 1 & 4 and upon removal of the spark plugs, I noticed the pistons
of 2 & 3 looked wet (unburned fuel I guess), whereas 1 & 4 were dry. I then tested the spark plugs by turning the engine over with the plugs
out and yes 2 & 3 were not working, 1 & 4 fine.
This suggests that the coil serving 2 & 3 is knackered - is it reasonable to presume that the false-neutral sent the revs sky-high and
consequently blew the coil? I don't know how many revs it was doing when I was periodically in neutral but I'm guessing it was high!
If anyone has any spare carbed R1 ignition coils then please let me know!
nitram38
posted on 21/8/06 at 11:34 AM |
Try swapping the coils over before spending any money.
Ferrino
posted on 21/8/06 at 11:43 AM |
Hi - i took the trigger wire from the 'good' coil (which fires 1 & 4) and transferred it to the 'bad' coil to see if it
would fire 2 & 3 - it did not, so I assume the problem lies with the 'bad' coil and nothing 'upstream' (I can take the
trigger wire from the 'bad' coil, transfer it to the 'good' coil, and it fires 1 & 4 fine).
bike_power
posted on 21/8/06 at 11:49 AM |
Check the compression too but hope it's justs a coil !
spunky
posted on 21/8/06 at 12:09 PM |
Don't want to sound negative, but there is no reason I can think of why hi revs should blow a coil.
Hopefully it is, but more coincidance than cause.
Also rev limiter should protect the engine from any damage.
John
The reckless man may not live as long......
But the cautious man does not live at all.....
Coose
posted on 21/8/06 at 01:46 PM |
When you sawpped coils, did you swap plugs too? A wet plug will not fire....
Spin 'er off Well...
Ferrino
posted on 22/8/06 at 09:49 AM |
Did the Yamaha tests on the coils and they were both fine! The only wires I did not test were the +12V feeds to the coils - one of them was dead! It
is the +12V feed to each coil that is cut by the ignition-interrupt box and it seems that on the upshift, the power to both coils was cut, as normal,
but one regained power and the other didn't, hence the misfire. I don't think I actually hit a false neutral at all, it probably just
seemed so from the lack of power from the misfire. Have now removed interrupt box.
CHEERS!
Ferrino
posted on 25/8/06 at 03:48 PM |
One more thing - do you think I should replace the spark plugs on the non-firing cylinders? I had to drive about 6 miles with only 1 & 4 firing,
to nurse the car home. ta.
Coose
posted on 25/8/06 at 10:18 PM |
Yes. Unless you bung them in the oven on gas mark 5 for an hour they'll be stuffed...
Just don't let Mrs Ferrino know if you do!
