bebot
posted on 29/8/06 at 04:33 PM |
Dimensions
Ok, i've managed to blag some material for the end plates on a de-dion axle but now i'm ready to make them who's dimensions for the
hub carrier do i follow?
The ones on Ned's photo archive or the ones on Rorty's plans?
Help, please.
3GEComponents
posted on 3/9/06 at 11:23 AM |
Hi Craig.
I can still supply a kit if you want.
But if you want to make it all yourself.....
The dimensions in Neds archive are correct, and so are Rorty's, where i think you are getting confused is where the holes are. they should be
47mm either side of the centreline on one side and 45mm either side on the other.
The 47's should be 25mm up from the centre and the 45's 28.5mm down from the centre.
John
