dt21jb
posted on 11/9/06 at 04:44 PM |
how to
right i'm putting a zzr1100 engine in my locost and using a sierra diff and going to use a prop shaft but how do i attach it to the bike
engine
and all so do you need a reverse gear for the sva test.
StevieB
posted on 11/9/06 at 04:50 PM |
You need a converter that attaches to your bike engine front sprcoket spline, this then lines up with the prop (which will need to be modified - speak
with GTS about this)
No reverse needed for SVA, and I've not heard much good said about the reverse gearboxes available - even the quaife unit is reportedly
unreliable. £600 better spent elsewhere!
dt21jb
posted on 11/9/06 at 04:54 PM |
prop
is the prop going to totally custom built or can you use something off a different car or van. im a fab/welder so cutting down and welding up
would'nt be a problem and getting it lined up, i can get on a lathe to do this.
dt21jb
posted on 11/9/06 at 04:56 PM |
prop
how much did the two piece prop set you back from bailey morris
