Author: Subject: Mooky going even faster Video
mookaloid
posted on 17/9/06 at 07:22 PM Reply With Quote
Following yesterdays video
Linky
Todays best run was over half a second faster although not quite as smooth.....
Link2
Better quality video today too!
Mark
jacko
posted on 17/9/06 at 07:37 PM Reply With Quote
Mark Congratulations on another great run Graham
monkey69
posted on 17/9/06 at 07:45 PM Reply With Quote
Nice run, looks like you caught a nasty bit of kerb at the end there
Well controlled with the full opposite lock though, that's what quick racks are for then
posted on 17/9/06 at 08:02 PM Reply With Quote
Cool vids Mark - glad my explanations got you sorted!
skydivepaul
posted on 17/9/06 at 08:08 PM Reply With Quote
what times did you get today Mark?
looks like you need a taller second gear in that box.
on the last hillclimb i did at harewood in august I am going into 4th downhill, 2nd on the esses, briefly snatch 3rd before farm.
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
mookaloid
posted on 17/9/06 at 08:44 PM Reply With Quote
Thanks to Steve for explaining google video to me
That was a 68.24 today - not the fastest in class, but the fastest pinto!
cutting the corner at the end is neccessary to get over the finish line without losing too much speed - and yes i'd be stuffed without the quick rack
gearing - thinking of a lower diff ratio possibly 4.44 or similar this would give more gearchanges but better acceleration loads of cash though!
Mark
mookaloid
posted on 17/9/06 at 08:50 PM Reply With Quote
Originally posted by zilspeed
You're trying harder on the 2nd run - so it seems from here
I have a friend who maintains that if you aren't right on the bleeding edge of what you and the car can deliver then it ain't worth bothering. I get that now - I suspect you do as well...
P.S. Well done.
Quite right, the second run was on the ragged edge........
But hung on to it though
skydivepaul
posted on 17/9/06 at 09:05 PM Reply With Quote
million dollar question.....the time you gain by briefly going up a gear for a few seconds and going that bit faster is it negated by the time it takes to change gear??
HD CCTV
IP security systems
mookaloid
posted on 17/9/06 at 09:19 PM Reply With Quote
Good question. this is the first time I have had chance to look at the speeds achieved (I don't have time to look at the speedo when driving) I think I would be over the peak on the revs if I left it in second for the whole run. I keep it in the power band better by changing up into 3rd.
I'm running a 3.92 diff now - I could reinstall my 3.64 diff which would help to keep it in second that but then I'd lose on acceleration.
Actually I need more acceleration so I'd be looking to go to a 4.44 diff which would mean another change into 3rd before orchard corner but I think I would have been there quicker in the first place.
I don't think my gearchanges are particularly slow after all
Mark
mookaloid
posted on 17/9/06 at 10:19 PM Reply With Quote
Thanks mate,
I can tell you've done a bit of this yourself!
Mark
mangogrooveworkshop
posted on 18/9/06 at 07:10 AM Reply With Quote
Must be those winddeflectors carving a hole in the air
Well done mate
NS Dev
posted on 24/9/06 at 11:04 PM Reply With Quote
Linky
Link2
Mark
Nice run!
Torquey blighter that pinto isn't it!!!
Toady1
posted on 25/9/06 at 07:53 AM Reply With Quote
it wont work for me? says they arent available at this time!
