Jumpy Guy
posted on 23/9/06 at 05:44 PM |
another DIY question - Rain Diverter kit
Today is DIY day, so that tomorrow is car day!!
so... we have a water butt that i wanted to fill from the house gutter. Bought a rain diverter kit which suggests cutting 30mm out of the downpipe,
then putting in the rain diverter with a hose to the butt.
all well and good, but the rain diverter itself is about 120 mm, so i assume that most people cut the 30 mm section out, then push the lower part of
the pipe down to allow the diverter in. then pull up the lower part of the pipe until it fits into the underside of the diverter..
one problem- the lower part of the downpipe is concreted in, so i cant move it...
anyone else fitted one? am i missing summat? ( very likely....)
scotty g
posted on 23/9/06 at 06:00 PM |
I seem to recall that you can get a collar type connection where you drill a hole in the downpipe then wrap a collar connection round where the hole
is and clamp it in place, it has a female fitting to push the pipe for the water butt into and an inset that goes into the downpipe a small way to
catch the water, just can't remember its actual name though.
Jumpy Guy
posted on 23/9/06 at 06:18 PM |
that sounds ideal. anyone else know what its called?
cant seem to find this 'collar type' on the web..
posted on 23/9/06 at 06:44 PM |
If you undo the clips above the diverter then push it upwards onto the end of the pipe it only needs to lift high enough to slot into the lower
section. The one I had did anyway. Make sure you have your water butt in it's final place before you cut so you can get the level
[Edited on 23/9/06 by Peteff]
StevieB
posted on 23/9/06 at 07:23 PM |
You can get the collars from B&Q - they have to suit all sizes of pipe and are really easy to fit.
Just remember to drill the hole before fitting the collar and plumbing everything in - we spent ages wondering why there was water pooling in our
dishwasher until Realised I'd done everything right apart from forgeting to tap a hole into the waste pipe under the sink!
Just
posted on 23/9/06 at 08:51 PM |
With mine, I undid all the wall brackets and that allowed enough flex on the downpipe to pull it away from the wall, far enough to get the diverter
in.
