New Topic New Reply
Author: Subject: Rivnut Tool
cmalc
posted on 5/10/06 at 12:13 PM Reply With Quote
Rivnut Tool
Can anyone reccomend the best Rivnut tool to buy (VFM) and where to get one.
I bought one when I started my build, used it twice and snapped the threaded bit off the bu**er.
StevieB
posted on 5/10/06 at 12:26 PM Reply With Quote
Where in UK are you?
There's a auto jumble at rufforth airfieldnear York first Saturday of every month that's usually good for that sort of thing.
Ian Pearson
posted on 5/10/06 at 02:26 PM Reply With Quote
I've just bought a Z100 from ZYGOLOGY
It's a quality item.
Regards, Ian.
daviep
posted on 5/10/06 at 02:32 PM Reply With Quote
In my experience the pliers used for setting rivnuts tend to be a bit crap. I've owned several sets and now use a home made tool which is a lot more reliable and gets into smaller spaces.
Very simple to make the main parts being a piece of flat strip with an appropriate size hole in it, a bolt to fit the rivnut and a nut to fit the bolt. Screw nut onto bolt, place bolt through flat strip and screw rivnut on to bolt so that the flat strip is nipped between the nut and the rivnut.
To set the rivnut simply hold the flat strip and the bolt head stationary and draw the rivnut up with the nut.
100% reliable and you can set the rivnuts nice and tight.
Cheers Davie
Marcus
posted on 5/10/06 at 04:07 PM Reply With Quote
We bught a Sealey one for about £50. Built 2 cars so far and still fine. (not tried steel rivnuts though)
Marcus
Because kits are for girls!!
cmalc
posted on 5/10/06 at 04:27 PM Reply With Quote
Thanks everyone. I like the sound of the home made jobby so I think I will have a go at that before I part with anymore cash....
COREdevelopments
posted on 5/10/06 at 04:37 PM Reply With Quote
i too made my own as a good rivnut tool is expensive, have a look at mine, may not be the best but it works, also gave me ideas on how to improve it, so i recommend making one, much more fun than spending your hard earned cash.
[Edited on 5/10/06 by COREdevelopments]
RichardK
posted on 5/10/06 at 06:00 PM Reply With Quote
I made one too, pictures in my www
Regards
Rich
givemethebighammer
posted on 5/10/06 at 07:25 PM Reply With Quote
David Jenkins has plans for a good one on his site:
http://www.dwjenkins.plus.com/riv-setter.htm
Or a crude version can be found here:
http://www.fjr1300.info/howto/rivnut-tool.html
whitestu
posted on 7/10/06 at 11:50 AM Reply With Quote
I bough the Zygology 7486 Boxed Kit - had no problems at all with it.
Not cheap though.
Stu
Hursty
posted on 9/10/06 at 08:31 AM Reply With Quote
Well I made one at the weekend and it worked a treat. Saved a few beer vouchers there! Thanks to everyone for the help.
cryoman1965
posted on 9/10/06 at 06:52 PM Reply With Quote
Can we have a picture of your efforts please!:
New Topic New Reply
