New Topic New Reply
Author: Subject: gts wishbones
COREdevelopments
posted on 12/10/06 at 09:50 PM Reply With Quote
gts wishbones
hi i am in need of some wider wishbones as the rear is alot wider than the front due to a different live axle that im using.
i have a set of luego bones to take the sierra hubs, does anyone know if GTS bones are wider than normal book spec, or is there any other wider bones that i can use???
any help would be kindly appreciated
thanks
Rob
flak monkey
posted on 12/10/06 at 09:53 PM Reply With Quote
The std GTS front bones are to make the front the same track as the rear of a sierra. So yes they are longer than 'book'
Sera
http://www.motosera.com
COREdevelopments
posted on 12/10/06 at 10:03 PM Reply With Quote
thanks david, do you know how much wider they are, am i right in thinking that they are the same as ones in rallydesign??
AdamR
posted on 12/10/06 at 10:12 PM Reply With Quote
GTS do both book and wide-track wishbones, and yeah, they are stocked by RallyDesign.
dozracing
posted on 16/10/06 at 01:34 PM Reply With Quote
Rally Design don't yet stock the wider wishbones.
Kind regards,
Darren
New Topic New Reply
