timbo7
posted on 15/10/06 at 11:43 AM |
5 speed type 9 stripping
Where can I find an online set of detailed instructions. I've a damaged tooth on 1st gear that is causing a knocking noise in 1st
WESTFIELD HAYABUSA 1400 - SOLD
mookaloid
posted on 15/10/06 at 11:48 AM |
If yours is a standard box you would probably better off just getting a used one for £20 from ebay or there is bound to be someone on here with one
for sale.
If it's a quaife or something then you'd be better off getting specialist advice anyway.
I'm not sure if the gearbox strip is in any of the Haynes manuals but I do believe that you need a specialist tool to get some of it apart.
Mark
posted on 15/10/06 at 11:49 AM |
There is a Haynes book on gearboxes that covers the Type 9 in great detail...
LINK
I got a copy out of the local library...
timbo7
posted on 15/10/06 at 11:51 AM |
cheers. guys.. Its a new BGH HD .. as I'm in NI I was going to send them the primary shaft to overhaul as its only 7 months old. Been knocking
like this sinse I got it.
omega 24 v6
posted on 15/10/06 at 01:31 PM |
Hopefully you have email.
