carlgeldard
| posted on 6/11/06 at 04:46 PM |
Bend Tech Software
Anybody know where I might find a free copy of Bend Tech Software on the net.
Carl
Agriv8
| posted on 6/11/06 at 05:24 PM |
I doupt youll get a free copy as the software key is very good.
Marc at MNR uses it for the Chassis development, roll cage and exhausts.
The install creates 1 key that needs to be sent to the software company for them to send you one back . The key will be different for each PC it
installed on .
Think thats Right.
regrads
Agriv8
tks
| posted on 6/11/06 at 05:29 PM |
muahhh
that means nothing
inventor uses the same stuff
and there are all over the place generators for it..
Tks
rebelrider
| posted on 6/11/06 at 06:44 PM |
AutoCAD is the same and theres a generator for that to save people the few grand that it costs to buy.
well.... so Ive heard anyway not that I would dream of getting a program with a crack in it.
marc laptop
| posted on 6/11/06 at 06:49 PM |
yep has a phone activated code also
probably unlikely for this programme not very mainstream
what do you want designing carl sure i can do it for you and send a screen shot of it if it helps
best regards
marc
carlgeldard
| posted on 6/11/06 at 07:59 PM |
I'm buying some tube bending equipment at work and I just wanted to save a few quid. I also wanted to have a quick play with it to see if we
really need it as we have two seats of Inventor CAD software.
Carl
marc laptop
| posted on 6/11/06 at 08:20 PM |
hi carl if you are in the area i will show you it working, its very quick and simple to use normally 1 minute from input of measurements to
instructions being printed, also does assemblies now so you can design a whole frame and split into sections tells you notches etc, also has reverse
engineering and simulation to ensure no binding or damage to machine
best regards
marc
carlgeldard
| posted on 7/11/06 at 02:48 PM |
I just might take you you up on that offer Marc cheers I will be in touch.
Cheers Carl
| posted on 7/11/06 at 03:53 PM |
There's a little program called bend it free to download which works out where to start your
bends. It only does one plane but it works for roll bars and locost boot hoops.
[Edited on 7/11/06 by Peteff]
carlgeldard
| posted on 7/11/06 at 04:45 PM |
Marc I see you get everwhere Clicky
I will try that pete
Carl
