<<  1    2  >>
Author: Subject: Help Stuck Dowel
carnut
posted on 17/11/06 at 05:15 PM Reply With Quote
Help Stuck Dowel
Ive got a dowel stuck in a blind hole and cant remove it. Its flush with the surface so cant get a grip on it. Its hard as hell so cant drill it. Tried heating ali casing in the hope it would expand and leave the steel dowel slack. I think the dowel is in a tapered bore at the bottom so its well and truly jamed.
I havnt got a welder handy either. The dowel is about 6mm in diameter.
Please post any suggestions so i can tell you that ive already tried.
thanks
Mark
DIY Si
posted on 17/11/06 at 05:17 PM Reply With Quote
Got any pics?
Sun Tzu, The Art of War
carnut
posted on 17/11/06 at 05:21 PM Reply With Quote
Sorry but ive you have seen the dowel in a bike gearbox output shaft bearing/case. Its one of those.
DIY Si
posted on 17/11/06 at 05:23 PM Reply With Quote
Might not be locost, but get a bike shop to pull it out?
carnut
posted on 17/11/06 at 05:27 PM Reply With Quote
Im not sure what they can do that i cant. I would get some1 to weld something to it but i'd have to wait till monday for that.
stevec
posted on 17/11/06 at 05:34 PM Reply With Quote
I reckon Japanese bike dowels are case hardened so that will cause extra probs if you try to drill it out.
Steve.
posted on 17/11/06 at 05:52 PM Reply With Quote
Araldite something to it, to give you something to pull??
Phil
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 17/11/06 at 05:53 PM Reply With Quote
Can you drill in from the "back side" then tap it out?
Alternatively you may have to leave it and drill another dowel hole else where.
John
russbost
posted on 17/11/06 at 05:58 PM Reply With Quote
Possible to machine a "stepped dowel" & insert this inside the stuck one, or insert smaller dowel to fit & put another of the existing size into the outer half of the case?
posted on 17/11/06 at 06:03 PM Reply With Quote
Powerful magnet?
carnut
posted on 17/11/06 at 06:04 PM Reply With Quote
It cant be drilled and its been rammed into a cast hole at the bottom of the machined hole which will have draft on it so its bloody tight. Dont want to drill the cases to get it out or add another dowel either as it might weaken the structure.
DIY Si
posted on 17/11/06 at 06:08 PM Reply With Quote
Is another case expensive? Otherwise machining the centre out to allow it to be removed, or to fit a smaller/stepped dowel may be the only way.
carnut
posted on 17/11/06 at 06:13 PM Reply With Quote
If i could machine it, i could remove it. I have more cases but they are 100miles away and need stripping. And my other cases dont have the engine no. to match the VIN.
flak monkey
posted on 17/11/06 at 06:14 PM Reply With Quote
You either need to have it spark eroded out if its that hard, or buy a solid carbide drill to drill it out.
If you can drill it and tap it you can use a slide hammer to pull it out.
Sera
http://www.motosera.com
hector
posted on 17/11/06 at 06:27 PM Reply With Quote
IF you can drill a hole through it....... you can remove it by filling the hole with oil and using a snug fitting punch (in the hole you just drilled) gently tap with a hammer and the hydraulic pressure will drive it out! It really does work.
posted on 17/11/06 at 07:04 PM Reply With Quote
Cobalt drill bit ? Find them very good , masonry drills are very hard if you can get one to start . Failing that as David says spark erosion
froggy
posted on 17/11/06 at 08:45 PM Reply With Quote
find a tap which will just about go in and try to get the tap started then wind a nut onto the tap to gve you something to pry against with a heel bar , its worked for me in the past just thought is it a hollow dowel?
owelly
posted on 17/11/06 at 09:57 PM Reply With Quote
Chew out as much as you can with a Dremmel. Try to grind a slot into it and try to colapse it inwards.
http://www.ppcmag.co.uk
ReMan
posted on 18/11/06 at 08:25 AM Reply With Quote
I'd second that, dremel is probable the kindest option, so with a small grinding stone, the mountes ball type you could almost drill it out.
Actually I'm not sure its clear wether this is a solid or a hollow type dowel your talking about here? either way still dremel if hollow then slot as abovw, if solid then grind top, you may even find it drills once case hardening is broken through
carnut
posted on 18/11/06 at 11:23 AM Reply With Quote
Its a solid dowel else it would be a doddle. Im going to the hardware shop to see what they have in the way of drill bits/ grinding bits. I dont want to break the top off it else it would leave me with a worse problem with it below the surface.
posted on 18/11/06 at 11:26 AM Reply With Quote
Soak in release agent for a few days then drill a small hole and use a stud extractor (gently)?? You do have to be careful though- those extractors can shear and they're bloody hard metal as well....
I had to drill through rock hard steel a while back.. My old bits didn't fancy drilling through it but a new shiny set of titaniums starting small and working up got there slowly. Helps if you've got a powerful low speed drill. I used a 12v portable drill wired up to a car battery.... which was just about perfect for drilling steel (and V powerful)...
[Edited on 18/11/06 by BenB]
posted on 18/11/06 at 01:15 PM Reply With Quote
this will go down as a classic, ironic isn't it. Welding something to it may be difficult if the dowel is only small and risks arcing to the aluminium, is it only to locate the casing?
carnut
posted on 18/11/06 at 04:07 PM Reply With Quote
The dowel is to hold a bearing outer from spinning.
Ive made some progress. I ground a slot across the dowel with a dremmel and i can now rotate it with a screwdriver. Next stem is to epoxy something to the top of it to try and pull it out. Will be a pain as theres likely to be the suction problem as i pull it out.
flak monkey
posted on 18/11/06 at 04:26 PM Reply With Quote
If you can turn it with a screwdriver its not that stuck.
Degrease it well and gluing something on might just work.
Sera
carnut
posted on 19/11/06 at 09:11 PM Reply With Quote
Tryed gluing something to it and it didnt work. Next stage is to weld something to it unless any1 has any bright ideas.
<<  1    2  >>
